Old 10-31-2011, 01:41 AM   #1
profe56
Pcv hose valve and booster hose possition
I'd like to know where exactly is the the PCV valve hose and booster hose.
I think one is conected behind the base plate at the carburator and other at the intake between carb and distribuitor. But what is the right place for one and other.
profe56 is offline   Reply With Quote
Old 10-31-2011, 02:10 AM   #2
MusicMan70
MusicMan70's Avatar
Re: Pcv hose valve and booster hose possition
Well here's the booster hose; going to the vacuum tee, behind the carb from the brake booster.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 10-31-2011, 02:16 AM   #3
MusicMan70
MusicMan70's Avatar
Here's where the pcv hose goes on my quadrajet. It's the big thick one in the middle under the fuel filter housing. Hope that's what you meant.
MusicMan70
1961 GMC Suburban
Old 10-31-2011, 11:28 PM   #4
profe56
Thank you.
Also I think the metal line conected with a hose is for the advance?
Old 10-31-2011, 11:47 PM   #5
MusicMan70
MusicMan70's Avatar
yes, I believe that is correct.
MusicMan70
1961 GMC Suburban
