Old 10-30-2011, 06:32 PM   #1
tony33
tranfer case model
Hello friends
I drive a 1500 2003 chevy extended cab 4wd whats model its my tranfer case? there;not tags o identificacion plate but a have the round button auto,4lo,4hi,2w i asume have the autotrac sistem but i tried to do an oil change for tranfer case and found red oil like transmision fluid i drive my last car was a 1500 4wd chevy pickuo 2001 and use a blue color transfer case fluid my question is i have a diferent model tranfer case? o somebody mess out my truck? I have two month old with this truck
tony33 is offline   Reply With Quote
Old 10-30-2011, 08:21 PM   #2
truckdude239
truckdude239's Avatar
Re: tranfer case model
most of the t-cases use the new dexron 5 on chevys,
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-30-2011, 09:58 PM   #3
clinebarger
NVG 149-NP3 Manual Transmission Fluid GM P/N 88861800
NVG 246-NP8 Auto-Trak II, transfer case fluid, GM P/N 88900402
NVG 261-NP2 Manual Transmission Fluid GM P/N 88861800
NVG 263-NP1 Manual Transmission Fluid GM P/N 88861800
If you have a Auto-Trak use the GM Fluid, All other transfer cases use Dexron III.
Since "Money Hungry" GM introduced Dexron IV, Dexron III is being phased out as a product name. It was renamed Manual Transmission Fluid part # 88861800
DO NOT use Dexron VI in place of Dexron III/manual transmission fluid in any manual transmissions or transfer cases that specify Dexron III, as a failure may result.
NP1, NP2, NP3 & NP8 are RPO codes......Look in your gloveblox & know for sure what case you have
clinebarger is offline   Reply With Quote
Old 10-31-2011, 02:27 PM   #4
biggsteve97
Originally Posted by tony33 View Post
Hello friends
You have the Auto-trac transfercase if you have the Auto button. The original Auto-trac fluid used until roughly 2003-2004 was red however the replacement Auto-Trac II fluid is blue and unfortunately seems to be only available at the GM dealer. The new fluid is supposed to protect better than the red fluid.
biggsteve97 is offline   Reply With Quote
Old 10-31-2011, 05:19 PM   #5
truckdude239
crap wish i had known that when we did the 100k on our 03 s-10 zr2 the dealer told us to fill the tcase with dexron vi
David fuller
2000 Tahoe 5.3l 378
