Old 10-25-2011, 12:04 AM   #1
cb1965
cb1965's Avatar
camper shell.....
im not a big fan of camper shells but was thinking of a wild idea. Unfortunatly i do not pocess fabricating skills nor the equipment to attempt anything.
Lets say you have a beyond repairable 60-66 chevy/gmc suburban or panel.
Cut and make the top back end into a camper shell to put on a regular swb
or lwb truck giving the illusion that you have a sub or panel. Am i crazy or is
this a cool idea? when ever you want it to be a truck just simply take the
shell off.
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 10-25-2011, 12:07 AM   #2
losthope
losthope's Avatar
Re: camper shell.....
Sounds good! Now we just need someone to photo shop the idea so we can see it! And sub windows on the side probley would look better imo then a panel
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 10-25-2011, 01:14 AM   #3
Captainfab
60-66 Nut
I was going to do this about 20 years ago, but I ended up having to move and had to get rid of my 3 parts Suburbans. It could be done with enough time and the skills to fabricate. Although I think it would be a bit heavier than a typical canopy.
Old 10-25-2011, 05:36 AM   #4
krazy_texan
krazy_texan's Avatar
That would look really cool but i would hope that you didnt have plans to remove it very often sounds like it would be pretty darn heavy
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 10-25-2011, 05:48 AM   #5
Woogeroo
these are on old stepside chevy trucks, but I always thought they worked really well:
camper shell pics
-W
Woogeroo is offline   Reply With Quote
Old 10-25-2011, 08:32 AM   #6
'63GENIII
'63GENIII's Avatar
I've always wanted one for the stepside although I've never thought of using cutting a Sub to do it. A narrowed Sub back half....Hmmmm. Neat idea! Only negative I could think would be the weight? I think it would look way cool!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-25-2011, 04:34 PM   #7
cb1965
cb1965's Avatar
i guess i forgot about the weight... i would still like to see a photoshop pic of it. anyone know how to do one?
'66 chevy lwb c10
'65 chevy lwb c20
Old 10-25-2011, 08:10 PM   #8
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
A fiberglass shell of a panel truck would be handy, then you could insert windows or not. A lot of contouring to follow the back of the cab. A hatch at the back with or without windows. 4 sizes for each style box.
Found this in my Silver Book, the parent company still exists.
Old 10-26-2011, 04:41 PM   #9
krazy_texan
it might be alot of work but weight wise why dont you get a fiberglass topper and cut it up or do whatever you need to do it to with more fiberglass to make it look like the back of a panel or suburban
Krazy Texan
1990 v1500 suburban
Old 10-26-2011, 05:51 PM   #10
Slow Build
Slow Build's Avatar
It would probably be best to use a sub or panel to make a mold then build it out of fiberglass.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
