what about this motor?
There is a guy coming to buy my Cougar today, and I'm already planning on dumping a fistful of that cash into my BlackTruck project. I'm eyeballing this motor, but I don't know what I should really be looking for...
http://atlanta.craigslist.org/nat/pts/2648045323.html ![]() What questions should I be asking this guy to make sure it is a good motor? What are ya'lls opinions on this motor in general? I've bought a pantload of things off Craigslist, but never an engine that I couldn't drive. Thanks!!
My 68 cougar restomod build:HERE |
Re: what about this motor?
looks impressive for the price, ask for a build sheet or the specs on the rebuild. Was it a garage build or built at a shop? Garage builds can be leery since you cant verify quality of parts. Just my .02
![]() Join Date: Jul 2010
build ya own or go crate...that is risk
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
Receipts , Receipts , get every lil speck of info from who built it to where the parts were purchased and whats is inside . if he cant provide any I would be hesitant
Scott 82 step side aka " Bouncy " 73 GMC Long bed Vortec 5.7 |
If you cant go for a drive w/the motor powering the vehicle, you're gambling. Some win, some lose. If it's sitting on a stand, I wouldn't give .50 on the dollar of the parts receipts unless there's a personal relationship (somebody knows somebody deal...).
The One And Only !!!
The most important thing you could ask him is make it run, I've had sellers crank um up on a old tire on the ground, No cranky I don't buy.
I've heard of quite a few people getting burned buying "good" used/rebuilt engines, Be very very careful.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
With that little cam and not much more info, that's not a 525hp 396. If you can't hear it run, there's no way, I would spend that much. Even at that, I would be leary.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
What heads are on it? It will need aftermarket high flow aluminum heads to make that much HP. I doubt the motor pictured is the actual one for sale, probably just a stock picture he found. If you take a look and it has GM iron heads on it, then the seller is probably full of it.
1977 GMC Sierra Grande |
What the others said, I doubt that is a 500+ horse motor with that small a cam. I had a similar size in a 468 with alum heads that barely made over 500.
Not saying small big blocks aren't worth anything, but whatever you do to them, you can get a whole lot more doing it to a 427/454....just my .02....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
Happy to be here
![]() Join Date: Mar 2000
I would never buy from an unknown source.
I agree with what everyone has said about being reluctant on buying a motor of that caliber from someone you don't know, with no guarantees. However, if that indeed is the motor pictured and you could hear it run, drive, and verify $ with receipts, and you get all that's pictured, and the trans. Regardless of the HP I doubt you could build it for that. He's obviously hurting for $ or he wouldn't be selling it. If you can hear it and drive it, and want it, I would make him that .50 on the dollar offer at around $3k or less. Just a little different view point. Good luck.
#12 | |
All great advice, thanks!
The cougar sale fell through, so it'll have to wait until the next buyer comes around. And I was SO excited to get to go shopping this weekend!!
