Old 10-30-2011, 09:31 AM   #1
Harley1650
1963 C-10 BBC/Muncie 4 spd
Harley1650's Avatar
door not closing tight
I've searched on door adjustment here but I still don't understand so hopefully someone can explain it to me in dummy terms.....My drivers door latches but doesnt close tight, it is about 1/4" ajar. As you know, there is no adjustment in the latch or door striker, so how on earth do I make my door shut tight?????
Harley1650 is offline   Reply With Quote
Old 10-30-2011, 11:47 AM   #2
cb1965
cb1965's Avatar
Re: door not closing tight
There i some adjustment on the stiker. Losen up the 4 bolts and tap it in a bit. It wont be much but it might help. If you close the door and latches but still moves in an out if you tug on it adjust striker. If its fully latched but doesnt move when you pull on it it could be the weather strip not allowing the door to close flush with the cab.
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 10-30-2011, 12:01 PM   #3
Harley1650
Harley1650's Avatar
Well, it does latch but I can jiggle it. When you say to adjust the striker, thats where I dont understand. I loosened the screws and there is no movement so what am I adjusting?
Old 10-30-2011, 12:08 PM   #4
j.kirn
you need to adjust the wedge on the lower part of door
j.kirn is offline   Reply With Quote
Old 10-30-2011, 12:11 PM   #5
cb1965
cb1965's Avatar
The striker has glue or some type of sealant. After you losen the bolts pry the striker from tha cab. This will allow you to move it around a bit
'66 chevy lwb c10
'65 chevy lwb c20
Old 10-30-2011, 01:01 PM   #6
Corts60
Just here to tinker
Corts60's Avatar
Also, there should be two distinct "clicks" when you close the door slowly. If you are only getting the first one, then that is why it is jiggling a bit. But, as mentioned above, adjust that striker pad to let the door move in. What I found out in my old '60 was that you'd have to slam the door to get two clicks but then I realized there was slack in the inside door handle and if I took that slack out and then closed the door, it would shut super nice. These old worn out mechanisms will toy with you.
Old 10-30-2011, 01:31 PM   #7
Slow Build
Slow Build's Avatar
Visual aid.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 10-30-2011, 02:29 PM   #8
j.kirn
Again getiing the wedge adjusted first then adjust striker
Old 10-30-2011, 02:44 PM   #9
Harley1650
Harley1650's Avatar
OK, I'll check and fiddle with it. Sorry to sound like a dummy!
Old 10-30-2011, 03:47 PM   #10
Harley1650
Harley1650's Avatar
Sucess! The two click thing eluded me...lubed it up, played with the striker and BINGO! Another thing off the list!
Old 10-30-2011, 04:07 PM   #11
cb1965
cb1965's Avatar
cool
'66 chevy lwb c10
'65 chevy lwb c20
Old 10-30-2011, 10:36 PM   #12
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
this is what I did too , worked wonders
