putting a new motor in, need advice
So i got an I6 in my 66 now, but bought a complete turnkey rebuilt 327. seen in the pic. [IMG]
Re: putting a new motor in, need advice
Can't help you on motor mounts I already had a V8,but I bought a trans mount from Classics and I just drilled new holes in frame and bolted it up. When I put in my 700R4 I also had to shorten my driveshaft
![]() Join Date: Aug 2004
What size 6cyl? 230/250 and the V8 use the same perches, 292 uses 1 different one, I think passenger side. 700 is a common swap, like indian said, you can use your orig or buy one from CPP or Classic, drill and bolt.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#4 | |
If you are doing a frame off resto, save some money, after you buy the new trans mount and get the engine and transmission in, move the center crossmember back 1.5" it will center your wheels and tires in the fender well and I think it will also let you use your stock driveline, I believe we shortened my driveshaft about that much. You can save cash , get more room for the tires and wheels.......not a bad way to go. Kieth ![]() |
Any suburban auto trans crossmember up to `85 will fit fine for the 700, almost like it was made for it, you just need to drill two holes.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
ok. thanks for all the input. any ideas on what gears to run in the back, should i get a new radiator and also what about a shifter for the floor?
I'm running 3:73's also Jegs has a b&m floor shifter for around 125.00
Do you want to tie up valuable floor space with shifter...? Its up to you, or go to http://www.lokar.com/index.html
i've got a 66 that had a stock i6, i installed a 400 small block, with a 700r4. i used the front set of holes for engine mounts, stock small block engine pads, stock engine mounts.the stock driveshaft worked out perfect. i also used a mid 80's camaro trans cross member, but did have to put a 1 inch spacer under trans mount pad. i am running a trukool alum rad, that is wide enough to fit between inner fenders, though i had to fab a new battery box, about an inch smaller to accomodate. i will be running an aux. radiator heat exchanger, seeing as how my new rad doesnt have radiator cooling. i swapped out the steering column from 3.o.t. to auto column shift w/tilt. i hope it helps
Resistance is Futile
Rear gears in 60-66 trucks were 3:73 or 4:10 which is what the factory uses behind newer trucks with 700r4's. You should be good unless its been changed.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
![]() Join Date: Oct 2009
protrash - I always thought factory gears were 3.73:1 or 3.08:1 (the "option"). But I've also seen/heard several times that 4.10's were available too. Is there a definitive answer on what the standard and optional ratios were for 66? I'm just curious.
Williamsboys, I've a got 3.73 and a T5 which has a .72 (this one anyway) od gear. Not far off from a 700R4 4th gear - and I like that combo - still gives good low end plus smooth sailing on highway. Have cake and eat it too. Also, like my set-up, the 700 has a fairly deep first gear, so you could probably go a little lower numerically and still have tons of bottom end feel and do even better on the hwy. But I think your ideal gear is somewhere between 3.30-3.80 range. Nice lookin motor by the way! |
Jocko, if there were 3:08's available no one would complain about driving on the freeway!!
![]() I think 3:08 became available in the 67+ trucks. I have one in my 'burb(5-lug). Cap'n fab is pretty knowledgable and maybe he would chime in.
Just read thru the info section and there was a 3:07 'Max Economy' ratio. I dont see it listed specifically for 63-66. Lot of info on that list.
if im not mistaken i dont have a posi rearend. should i swap out rearends or can i change the guts to make it posi?
#15 |
do yall think i should buy a new radiator or just get mine checked and maybe cleaned out. also whats so great about the aluminum one to make them 500 dollars are they worth saving up for and getting?
#16 | |
I dont know what radiator you're looking at but it better install itself for 500 bucks. ![]()
#17 |
cool. thanks protrash64
#18 |
Use the Ebay Champion Aluminum rad, works great for me.
#19 |
clyde65 i found those rads thanks, do you run a mechanical or electric fan, if electric is it complicated to wire up?
