Old 03-25-2016, 09:49 AM   #1
65standard
65standard's Avatar
Dorman 615-183X intake
Has anyone used this aftermarket truck intake manifold? It looks good and with a little bit of work, it could look as good as the LS6 intake on the outside. It appears to be a direct replacement for the ugly truck intake for gen III motors.
The trailblazer SS intake seems to be for gen IV motors.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 03-25-2016, 09:59 AM   #2
XwalkerX
Re: Dorman 615-183X intake
but how well does it flow?
the stock truck intake manifold actually flows VERY well
XwalkerX is offline   Reply With Quote
Old 03-25-2016, 10:05 AM   #3
65standard
65standard's Avatar
I'm hoping it flow as good if not better than the stock truck intake. I just can't use the stock intake because it is too ugly. I'm building a hi-po 6.0L on a frame off restoration.
Old 03-25-2016, 10:10 AM   #4
XwalkerX
I cant deny it looks much better.
im just saying personally I would only consider it after finding a flow chart or dyno chart VS the stock intake manifold.
Old 03-25-2016, 10:15 AM   #5
65standard
65standard's Avatar
Agree, that is way I'm hoping someone has tried this intake already.
Old 03-25-2016, 11:15 AM   #6
XwalkerX
found this thread which had a pretty good side by side of the two
http://www.ls1truck.com/forums/power...ariants-2.html
Old 03-25-2016, 12:05 PM   #7
65standard
65standard's Avatar
Thanks for the link.
Old 03-25-2016, 11:57 PM   #8
roundhouse
google up some pics of "shaved intake"
roundhouse is offline   Reply With Quote
Old 03-26-2016, 12:51 AM   #9
Chris Coufal
I looked at those also. Seems like most of the chatter I saw about them was related to them holding boost. Like you, I want to get rid of the UGLY truck intake.....and the LS6 used intakes are not very cheap. Everything I read stated that with some mild porting these would be great intakes. I'm just not sure the time it will take to clean them up is worth the cost difference.
Chris Coufal is offline   Reply With Quote
Old 03-26-2016, 08:41 PM   #10
65standard
65standard's Avatar
Well, I ordered the Dorman 615-183X intake. Not sure what is different from the Dorman 615-183 intake. I'll let you guys know if it works out or not.
Old 03-26-2016, 09:05 PM   #11
Chris Coufal
GL....I purchased a complete LS6 intake off ebay today for $350 shipped.
Old 03-26-2016, 09:36 PM   #12
65standard
65standard's Avatar
I can't use a car intake. I would have to change everything. The Dorman intake was $199 shipped. Both truck intakes out performed the LS6 intake.
Old 03-26-2016, 09:39 PM   #13
Chris Coufal
That's not what I have read.....the truck intake out performs the LS1 intake. The trailblazer intake is the better one that really shines. The LS6 is about 15hp average for everything I have read. And ya.....I'm having to swap water pumps, TB's and run some adapters for the injector connectors.
Old 03-26-2016, 09:47 PM   #14
65standard
65standard's Avatar
According to Hotrod, the trailblazer intake out performed the LS6 intake in power and torque everywhere.
Old 03-26-2016, 09:56 PM   #15
Chris Coufal
You are right about the TBSS intake .....I'm referring to the stock truck intake. You stated "both" truck intakes out perform the LS6 intake. If you are referring to this test they did.....it was also done with cam and heads.....not stock pull-outs. http://www.hotrod.com/features/1507-...ifolds-tested/
Hard to compare apples to apples.
LS1- 535
LS6- 557
TBSS- 562
stock truck- 549
And I was assuming you were using a pull-out and just doing a swap. If that's not the case then I stand corrected and apologize. I'm no expert and am learning as I go through my build.
