Old 09-05-2011, 12:42 AM   #1
lenguini
lenguini's Avatar
E brake convert to foot operated mechanism
Anyone done this ? Thinking of updating to a late 60's foot e brake mechanism.Dont know if it can be done..,hope someone has or can recommend a way to do it.No longer a fan of the network under the dash !
Thanks in advance.
lenguini is offline   Reply With Quote
Old 09-05-2011, 02:07 AM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: E brake convert to foot operated mechanism
http://www.persh.org/pickup/DonsEBrake.htm
here`s a link for you..
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 09-05-2011, 11:52 AM   #3
lenguini
lenguini's Avatar
Thanks for the info,however the set up in the foot mech should work from a later 60s c10 as the e brake is all the same up to the firewall.Already finished the frame and dont want to weld or have to change system.
Thanks.
Old 11-05-2011, 11:41 AM   #4
lenguini
lenguini's Avatar
After much time and consideration,I went the way of the link you sent.I ended up mounting the cable through the original hole in the frame and then mounted the brackets inside the frame rail so the system is hidden.
Thanks again for the link Rich,appreciate it.
