Old 11-08-2011, 01:39 PM   #1
Classycustom71,95
Classycustom71,95's Avatar
Faster heater fan for my 1971 gmc
Hey guys, does anyone know what heater motor I could use to replace the factory to move more air? I was thinking of using something like I got in my 95 ..?
Classycustom71,95 is offline   Reply With Quote
Old 11-08-2011, 02:53 PM   #2
67chevemall
67chevemall's Avatar
Re: Faster heater fan for my 1971 gmc
The heater on high is more then enough. Just put a toggle switch on it.
check your rad to be full and the air tubes behind the dash if the heat isn't there.
I can cook eggs on my floor when it is on.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 11-08-2011, 02:57 PM   #3
Classycustom71,95
What do you meen about puting a toggle on?
I'm getting lots of heat it just not blowing enough air to keep the windows clear
Old 11-08-2011, 03:16 PM   #4
Classycustom71,95
Old 11-08-2011, 03:57 PM   #5
67chevemall
If it is the def on the windows your vent tubes behind the dash are probably dryed out and toast, leaking air.
OR
The resistor switch is probably toast. Do you get low to high?
You can bypass the switch...run a wire to the fan from the fuse box and put a toggle switch someplace. For more current run it from the battery with a fuse at each end and a toggle switch in the cab.
Old 11-08-2011, 06:31 PM   #6
Classycustom71,95
I'm going to pull the vent tubes off and check them out.
I like the idea of the toggle switch I'm going to try that
1971 gmc k10, 1995 chevy custom pickup
