Old 11-08-2011, 11:52 PM   #1
motiveauto
motiveauto's Avatar
Ignition Switch Removal
Hey guys, Im trying to remove the ignition switch from my dash bezel. It is impossible to remove it by unscrewing the retainer nut since the keyed area is larger than the nut. there are two holes on this particular ignition so i dont know if it is stock or not. Ive tried the paper clip trick to no avail. any ideas?
86 K20 6" lift
66 C10 LS2 T56
1947 Ford Rat Rod
Softail Deluxe
Softail Chopper
motiveauto is offline   Reply With Quote
Old 11-09-2011, 12:35 AM   #2
jocko
jocko's Avatar
Re: Ignition Switch Removal
there is a specialized tool to remove it - has two prongs that fit the holes, then twist. Now, if you want to try the approach I tried, I took two scratch awls, inserted in the holes, and gave em a big simo whannng... (I'm not kidding, but this was many years ago) It came off but the gouge I put in my dash made me want to cry. I now own the tool....
Old 11-09-2011, 01:52 AM   #3
PAPA KENT
PAPA KENT's Avatar
Take a small flathead screwdriver holding it at a angle to (push) or turn and tap lightly with a small hammer to turn it,that should work.
PAPA KENT is offline   Reply With Quote
Old 11-09-2011, 06:03 AM   #4
blackedoutharley
Do the paperclip trick while turning the ignition switch.... may have to play with it but should come right out.
blackedoutharley is offline   Reply With Quote
Old 11-09-2011, 08:27 AM   #5
62 Longbed
62 Longbed's Avatar
A pair of needle nose pliers , work wonders ....
62 Longbed is offline   Reply With Quote
Old 11-09-2011, 09:14 AM   #6
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
IF it's stock, then like blackedout says, the switch should have a tiny hole in the front into which you push something like a paperclip after turning the switch to the lock position, then as you push in, continue to rotate the key counterclockwise. you need the key to do this, which is why my switch is still in the dash.
2 holes, maybe not stock?
Larry
fleetsidelarry is offline   Reply With Quote
Old 11-09-2011, 08:11 PM   #7
motiveauto
motiveauto's Avatar
Guess what! I got it out!
Drilled out the two holes with a 1/8 bit, then used a pic to push down on the small brass pin.
Thanks for all of your help!
86 K20 6" lift
66 C10 LS2 T56
1947 Ford Rat Rod
Softail Deluxe
Softail Chopper
