Old 11-13-2011, 03:57 AM   #1
05crewcab
05crewcab's Avatar
messin with my horn...what is this nut for?
I am having problems with the contact disk for my horn touching my turn signal lever...seems like the disk slides on to the column shaft too far. on the shaft below the disk is this nut in the picture. what does this nut do?? if I unscrew it up a ways the contact disk stays off the turn signal lever, but I think the nut is to hold the bearing down, so it should be tight right?
'72 tilt column and a grant steering wheel
any help with pics and parts needed to get the horn working would be helpful...I feel like i might be missing a washer or something to that effect. Thanks.
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 11-13-2011, 07:42 AM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: messin with my horn...what is this nut for?
Been in there just recently and that nut is to compress the bearing and should be tight.
The only pic I have but it doesn't show the the contact disc.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 11-13-2011, 08:30 AM   #3
eightbanger
454 MAKES IT ROAR
Went outside to pull the wheel and take more pics, now can't edit the previous pic which is of no use, have to go and make another post.
What holds my contact disc up is the small plastic post on the back, it fits nice & snug into the female part on the aliminium adapter where the horn wire feeds through (see pic) and the adapter once it is slid on the splines sits just level with the start of the threads for the wheel nut (see pic).
Hope this helps.....
Nigel.
No more pain.
Old 11-13-2011, 11:52 AM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Are you putting a spring under the horn contact? I recall a spring.
sneakysnake is offline   Reply With Quote
Old 11-13-2011, 12:14 PM   #5
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
lol.....man does that thread title sound just wrong!
prostreetC-10 is offline   Reply With Quote
Old 11-13-2011, 08:10 PM   #6
eightbanger
454 MAKES IT ROAR
Nigel.
No more pain.
Old 11-13-2011, 11:47 PM   #7
05crewcab
05crewcab's Avatar
Haha...guess I wasn't thinking about the connotation in the title when I was pissed about my stupid horn last night at 2am!
Anyway, Thanks for the pics...I am definately missing the spring under the contact disc, and there is no wire for the horn switch. I just have a skinny two inch long spring that sits in the shaft of the contact disc which makes contact with the horn button. I might be up a creek without a new steering wheel hub kit.
1971 C-20 350/350
