Old 11-29-2011, 10:26 PM   #1
JNJchev77
Registered Cruiser
JNJchev77's Avatar
CPP Steering Joints
Do the CPP Steering U-Joints need to be painted to prevent rusting?
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 11-30-2011, 09:01 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: CPP Steering Joints
I have the "nickel" plated version.
I've heard from Porterbuilt that they do corrode when they get wet.
Not sure if it's the joint or the set screws and nuts.
I will use borgeson joints from now on.
http://www.borgeson.com/
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 11-30-2011, 11:41 AM   #3
Scottshotrods
The nickle plate will rust over time on the u-joints we had that issue back when we used to carry Flaming river joints.
As lolife99 said above Borgeson is the way to go and there is one more option to go with are Uni-steer u-joints they are S.S and they do have more adjustment than others on the market but they are bigger in dia.We have both in stock and if we can help you all out let us know.We have some good prices on both.
Justin
Scottshotrods is offline   Reply With Quote
Old 11-30-2011, 11:46 AM   #4
El Campo
El Campo's Avatar
How much are they both? I need to be buying one before long.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 11-30-2011, 11:46 AM   #5
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Thanks guys! I have the nickel plated CPP joints already, although I wish I would have gone with the Borgeson ones now, only because of the corrosion issue. CPP's work well, just like a little bit of bling and didn't want to cover it up. Guess I'll just paint em black and call it a day
77' Chevy SB
5.3/4l60e combo
Old 12-01-2011, 01:15 AM   #6
Scottshotrods
p/m sent
Justin
