Old 11-20-2011, 10:21 PM   #1
cfacundus
Steering Column help
Would anyone happen to have an exploded view of a 64 auto column. I pulled mine out to weld the retainer tabs back on and as you know one thing leads to another. I would like to try and freshen it up while I am in there. There is no telling what I may be missing or is put back together wrong given the PO track record. I have some play in the wheel itself like the center shaft is missing a bearing. I do have a bearing behind the horn contact but the play is so bad that it will click the horn relay just by moving the wheel around.I would also like to try and replace the shift bushings too and can't quite figure out how to get to them.
cfacundus is offline   Reply With Quote
