In-op heater ... help!
I have a 1971 C-10 (350 V-8, auto, RWD, long wheelbase) that originally had factory A/C ... but at some point the compressor was removed by a previous owner.
When I slide the dash controls between hot and cold, I can hear things moving and I can feel a temperature difference. However, when I move the fan switch nothing happens. I recently replaced the main fan switch on the dash ... but the fan still does not come on. At this point I guess it could be one of four things ... 1. Blower motor needs to be replaced ... http://www.lmctruck.com/icatalog/cb/full.aspx?Page=119 2. Blower motor resitor needs to be replaced ... http://www.classicindustries.com/search?q=G9825 3. Blower motor relay needs to be replaced ... http://www.classicindustries.com/search?q=AP5760 4. A bad ground and/or power wire 5. Or ??? Does anyone have a suggestion on how to make the blower work? Is this a common problem that is easily fixed? |
Re: In-op heater ... help!
U need to check blower mtr to see if it has voltage,other possible causes is blower relay located at heater case rh kick panel.u can send a hot wire from battery to blower mtr to see if it blows,also check grounds
Posted via Mobile Device |
Check and clean the ground connection first.
I swapped a used blower motor that bench tested fine, but didn't work when installed. Turns out the ground wasn't making good contact. Take a little sandpaper to the housing and terminal. My original blower was fine, but the bad ground fooled me. |
The Older Generation
5. Fuse.... If I remember correctly there has to be a fuse in the A/C slot before the blower will work. LockDoc
