Old 01-01-2012, 09:54 AM   #1
Restrorob
The One And Only !!!
Restrorob's Avatar
Pollution Pipe/Spider Removal
Friend of mine has a 86 with those unsightly pipes on the manifolds, We don't have emissions testing. The air pump seized the other day and he wants to strip all that crap off.
I have line wrenches and crow-feet but haven't tried yet, Are there any tricks to getting these fittings out easier ?
Thanks....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-01-2012, 11:31 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Pollution Pipe/Spider Removal
Penetrating fluid of some sort. Not sure if this will work for you, but If you don't want to save the lines, cut the lines off flush with the top of the fitting and use a 6 point socket on the fittings.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-01-2012, 01:43 PM   #3
cdowns
cdowns's Avatar
lots used to just snip and crimp the tubing some brazed the ends all worked for long lifespans // some used to do it that way right off the showroom floor brand new
Old 01-01-2012, 02:07 PM   #4
Psycho71
Psycho71's Avatar
I was going to remove the lines on my '85. That is, until I discovered they were not going to come out of the manifolds by using any method (penetrating oil, heat, nothing worked). So I pulled the manifolds to see what I might could do differently. I then discovered that the fittings these things screw into occupy about 30-40% of the internal opening in the primary tubes of the manifolds. So I went with a set of headers. Never regretted it, and would do it again without reservation.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
