Old 01-02-2012, 10:59 AM   #1
Tex_50613
Redneck Customs Bumpers, IA
Tex_50613's Avatar
Question gauge setup question for yall?
I have a gauge cluster out of a '74 C-65 that I plan on using in my 85 K-30 that I'm installing a 7.3L diesel in to render stock manual gauges (oil and air pressure specifically), also to give me a tach. and back date the truck to go along with the '73 front clip, the question I have is what additional wiring or re-wire do I have to do to the 85's interior harness to use the 70's stock cluster with tach with the fuel gauge in it (if they work) also a good place to have that gauge repaired if it doesn't, also did Chevy ever run a volt meter instead of a amp meter? 95% of the Chevy's I've had up to this point have all had Idiot lights or aftermarket gauges.
here's the cluster I plan on using, I also have a spare light truck cluster if I have to replace any of the other gauges that may mot work after I get it all hooked up
Overkill is under rated, Redneck Customs Truck Club Hudson, IA
"Clifford" 83 Chevy K20 4x4, Mudder 7" lift rolling 44's
"Basterd Child" 86 Chevy K30 4x4 crue cab Dule, 7.3l international WIP
'00 ex-cab Silverado 4x4 DD
I hate red trucks but you can't tell by looking at what I own
Tex_50613 is offline   Reply With Quote
