Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-09-2012, 06:56 PM   #1
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow NANO Nitrous Nitrogen Assisted Nitrous Oxide, Nitrous on Steroids!
Check this out fellas.... for those trucks haulin more than hay! Teehee....
http://www.nanonitrous.com/
NANO Nitrous
Located in Kansas, NANO (Nitrogen Assisted Nitrous Oxide) has developed advancements to optimize the use of nitrous oxide systems. NANO applies mass flow technology to continually "compensate for changes in bottle temperature and pressure" so the result is constant maximum horsepower gains for the duration of a race. NANO tanks are filled with high pressure air or nitrogen to 4500 psi. Complete regulator kits and accessories are available. NANO: "Turbo performance at nitrous prices."
NANO eliminates the performance variations in your nitrous oxide system caused by constantly changing bottle pressures and temperatures. Bottle pressure is no longer an issue. Simply connect the NANO system, it instantly compensates for these variations so you get the full power potential of nitrous oxide power every time you hit the button and it utilizes the entire contents of the nitrous bottle.
NANO doubles the runtime from a single nitrous bottle refill, traditional nitrous systems can only utilize about half the nitrous in the bottle. NANO's technology can utilize the full contents of a nitrous bottle without any loss in power.
Quicker ET's with NANO, no more deterioration of power as your nitrous bottle empties. You get the same power response every time whether you're nitrous bottle is full or almost empty.
Nano Nitrous LLC
• 811 E. 28th St., Lawrence, KS 66046
• Phone: (785) 331-2390
• Fax: (866) 422-5550
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
