Old 05-26-2011, 07:45 PM   #1
Pro Performance
Pro Performance's Avatar
Air Over Leaf Question
I am planning on running AOL on my 84 C10. Right now, I have 2 leafs with an overload, and a flip kit installed. How many leafs is recommended for this setup? I am going to remove the overload for sure.
Also, I am a little concerned about the leaf springs bending backwards. I am thinking of putting a drop shackle so that this does not happen. But, if I do the drop schackle and leave 2 leafs in, will the spring be too stiff, thus requiring more air to bring to ride height and causing a rougher ride?
Options:
A) 2 leafs with just a flip kit
B) 2 leafs with a flip kit and drop axle
C) 1 leaf with just a flip kit
D) 1 leaf with a flip kit and drop axle
Pro Performance is offline   Reply With Quote
Old 05-26-2011, 10:37 PM   #2
bagged74
its just $$$$$
bagged74's Avatar
Re: Air Over Leaf Question
I have 3 leafs, with a drop shackle on mine with AirLift sleeve bags. It goes all the way down until the pumpkin hits the bed floor. I can post a picture when I get home.
bagged74 is offline   Reply With Quote
Old 05-26-2011, 10:59 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
I assume you meant to say shackle here "B) 2 leafs with a flip kit and drop axle". That should be your starting point. DO NOT go to one leaf. The upper leaf is not designed to be run mono.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-26-2011, 11:17 PM   #4
Cherub
Cherub's Avatar
Good question. I had always wondered that my self
Cherub is offline   Reply With Quote
Old 05-26-2011, 11:36 PM   #5
bagged74
its just $$$$$
bagged74's Avatar
looks like Ken has the pictures covered.
Here is one of mine with the bed back on. The bed floor is sitting on the pumpkin in this picture
Old 05-27-2011, 10:26 AM   #6
blazer2007
how is your front done,I,m hoping spindles,coil, bag front.Please say no PB.or z frame.Is has just the right look.
blazer2007 is offline   Reply With Quote
Old 05-27-2011, 10:31 AM   #7
blazer2007
sorry found the answer on your profile
Old 05-27-2011, 10:34 AM   #8
bagged74
its just $$$$$
bagged74's Avatar
Just the standard cup on the bottom and plate on the top.
Old 05-27-2011, 12:08 PM   #9
Pro Performance
Thanks for the info and pictures. I will order up some shackles and leave just 2 leafs in, but I think I will pull the overload out.
How is the ride with this setup?
Also, what type of fitting would I need for the bag setup up front? I am using the plates.
A 45 degree? 90 Degree?
Old 05-28-2011, 04:16 PM   #10
harveyrc2003
harveyrc2003 is offline   Reply With Quote
Old 05-28-2011, 04:19 PM   #11
harveyrc2003
Would like to do air over leaf what all do need to do this. I know ride tech AOL kit but what else new at thish.
Old 05-30-2011, 02:27 AM   #12
TruAggression
TruAggression's Avatar
Depends on what your goal is.... like if your wanted to run compressors or just run em off schraeder valve. Probably would suggest sleeved bags if you ran a AOL setup too and possible limiting strap.
TruAggression is offline   Reply With Quote
Old 05-30-2011, 01:14 PM   #13
harveyrc2003
Old 05-30-2011, 01:16 PM   #14
harveyrc2003
If I want just AOL nothing on front do I need one compressor or two and what else. Thank you for ur help really new at this.
Old 05-30-2011, 03:10 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
If your going to run the rear only for now you can just run a single compressor. If you just want the ability to increase your towing capacity you can use Schrader valves and an external air source.
Articles-
"Refining Sierra"
Old 05-30-2011, 05:26 PM   #16
harveyrc2003
Want truck back in to sit low like urs later on will get front done from ride tech. So that's why I want to know what to get started with an how low will the back sit with c notch.
Old 05-30-2011, 05:27 PM   #17
harveyrc2003
Old 06-11-2011, 07:55 PM   #18
Pro Performance
I got the back all setup. How did you guys with AOL setup your shocks. This is a picture of my setup right now.
Got the rear airbag setup pretty much done. I still have to figure out where I am going to mount shocks. I haven't tried it yet, but I was told the 1-1/2 square tube will fit underneath the bed.
[/IMG]
Old 06-11-2011, 11:13 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
We moved one of my shock mounts to the rear to match the other. What made you go with convoluted bags over tapered sleeve?
Articles-
"Refining Sierra"
Old 06-11-2011, 11:19 PM   #20
Pro Performance
I know some of the people at Slam Specialties, and I believe you get a better ride and more travel out of a convoluted bag. These back go from 3" to 12".....
Regarding the rear shock. When the axle is all the way in the c-notch and touching frame, the frame is in the path of the shock.
Old 06-14-2011, 12:20 PM   #21
Pro Performance
Bagged74 - Regarding the front with 22's. Did you have to modify the inner fenderwells to fit the 22's? Do you have a stock crossmember? What drop spindles (2.5" or 3")? I am assuming your front is bagged as well.
Old 06-14-2011, 12:51 PM   #22
bagged74
its just $$$$$
bagged74's Avatar
The front inner fenders are taken out. The crossmember is stock and the spindles are 3" DJM. It is bagged with 2600 dominators
Old 06-14-2011, 01:12 PM   #23
Pro Performance
Thanks for the info.... I am using the same, but with Slam SS7's.
Old 06-14-2011, 04:12 PM   #24
gearheadtre
simple easy NICE!!!!
gearheadtre is offline   Reply With Quote
Old 01-13-2012, 08:18 PM   #25
91Subbed
Can these ideas be used a 91 suburban?
91Subbed is offline   Reply With Quote
