Old 01-15-2012, 09:55 PM   #1
1972RedNeck
1972RedNeck's Avatar
Speedometer
The other day when I took my truck on it's first maiden voyage, it felt like I was doing 80 when the speedometer said 70. I took the GPS with me yesterday on my trip to Helena. When I got to 63 mph, I glance over and the GPS says 70. Upon further inspection, my truck has 3.73's instead of 4.10's like I thought.
So, what do I need to do change the speedo gears in my 205 transfer case? Do I have to change the gear on the shaft along with the driven gear? Do they make a speedometer adapter?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-15-2012, 10:04 PM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Speedometer
Go into Bowtieoverdrives site and surf around in there and I believe there is a chart which will give yo the info you need.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-15-2012, 10:16 PM   #3
1972RedNeck
Re: Speedometer
I assume the gears they recommend for a 700R4 fit the 700R4, not the 205, right?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 01-16-2012, 12:26 PM   #4
Already Gone
Re: Speedometer
All I know is whats on the page and I think tire size and rear end ratio are the two calculations you need. I think you can ordr the gear you need form them as well and if/when you order they should be able to confirm which one you need.
Old 01-16-2012, 10:01 PM   #5
1972RedNeck
Re: Speedometer
So I found this page http://www.transmissioncenter.net/sp...n_______va.htm
Go down to "GM / Dodge / Ford Ratio Adapter". I think I need the top one at 10% if my speedometer reads 63 when I'm going 70. Is this correct? I just want to make sure before I buy.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 01-16-2012, 11:37 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Re: Speedometer
Can't you just change the driven gear by using the chart near the top of the page? $11.00 compared to $62.00 is quite a difference... Just wondering.
LockDoc
Leon
Old 01-17-2012, 12:03 AM   #7
1972RedNeck
Re: Speedometer
Yup, good thing I posted on here. Sometimes my eyes are blind.
1966 F250 4X4 416
1972 K20 350 4 OTF
