Old 01-16-2012, 07:56 PM   #1
JumboAMONGus
JumboAMONGus's Avatar
283 4 speed question?
i have a 283 bored.125 over making it a 302 .or some call 301 ,it has a duntov 30/30 cam .with a 4 speed ..any one ever ran this combo and know of a good rearend that wont bogg down on take offs and have good cruising speed i have the stock rearend now so i asume its 4 .11s but i also have a camaro rearend probly has 2.73 i know will probly really suck just trinyg to figure good gears its not an everyday driver ,only thing holding me up is the rearend ,stock ones so worn the driveline turns half a turn before the gears kick in ,,lol
JumboAMONGus is offline   Reply With Quote
Old 01-16-2012, 08:15 PM   #2
xaircav
xaircav's Avatar
Re: 283 4 speed question?
The combination in my '53 is a '62 220 horse 283, an SM 465 trans and a 2.73 geared Camaro 10 bolt. I can take off in 2nd normally without a lot of clutch slip and cruise 70 at 2200 RPM with 255-70 R15 tires. Like TV cop Hunter used to say
"It works for me"
xaircav is offline   Reply With Quote
Old 01-16-2012, 08:23 PM   #3
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Ive got a 3.42 in my camaro right now with 28" tires, pretty good down low but also cruises pretty nice. Look into 3.55s.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 01-16-2012, 10:53 PM   #4
mr48chev
mr48chev's Avatar
I've run a twin to that engine in my 48 with a M21 Muncie and Camaro rear end with probably 2.90 or 3.08 gears and it didn't have any grunt on the bottom end at all. The granny trans would give you the extra grunt if you needed it though.
You will probably be fine as long as you don't try to tow something too heavy.
Old 01-17-2012, 12:34 AM   #5
solidaxel
solidaxel's Avatar
Nothing less than a 3:50 even better a 3:73!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-17-2012, 12:41 AM   #6
VWBeamer
I had 3.73 with a 4 speed muncie, I did drive the truck on the highway, but it's turning a lot of RPMs. I would go with a 3.42 or 3.55 unless you will be towing or racing a lot.
VWBeamer is offline   Reply With Quote
Old 01-17-2012, 02:31 AM   #7
JumboAMONGus
cool ,im running a borg warner t-10 out of a 62 impala , i need to check the rear end i have it was suposed to be a stock posi from 67rs but only thing is when i open it no posi so im not gonna go by the numbers ill count the gears but it was a 2 speed power glide car .
Old 01-17-2012, 11:19 AM   #8
mknittle
mknittle's Avatar
I was reading a old article on the 325 hp 327 yesterday in CHEVY magazine. the editor stated that most mid 60s chevelles with 227 m21,22 4speeds had 3.55 rears.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 01-17-2012, 11:32 AM   #9
mknittle
mknittle's Avatar
The T10s had several gear ratios so you might want to check that out also.
http://www.chevymania.com/tech/trans-ratios.htm
Mark
My GMC build.
Old 01-17-2012, 11:37 AM   #10
solidaxel
solidaxel's Avatar
That 30/30 cam will need a lot of gear to get going
LS 3 4L70E
Old 01-17-2012, 01:35 PM   #11
_Ogre
_Ogre's Avatar
JumboAMONGus
i run a 3.27 gear in an 86 trans am rear end and a 700r4 in my truk.
i wish it were closer to a 3.00 for mileage (as is i still get 20.1 mpg)
try it
shop air compressor timer
Old 01-17-2012, 03:45 PM   #12
JumboAMONGus
yes it does with the 30/30 cam ,its a wierd feeling driving if your gonna try and drive normal speeds. but once you hit about 3500rpm it kicks in ,no power on take off unless you dump the clutch ,thats with the stock rearend , plus running a holley 650 ran better then the holley 850 dbl pumper ,
Old 01-21-2012, 02:48 AM   #13
KingKlung
If you have a stock rearend most likely you have 3.90 gears as only the overdrive transmissions had 4.11's.
I ran a 1957 Chevy car rearend with 3.55 gears and a 1963 Borge Warner T-10 with close ratio. My cam was a CompCam with a 268 duration. The truck ran great back in the late 70's.
I would run either 3.34 to 3.55 to get both performance and crusing.
KingKlung is offline   Reply With Quote
