Old 01-21-2012, 02:51 PM   #1
dyno
dyno's Avatar
'58 Urethane spring bushing conversion?
I'm pulling my springs to have them re-arched for a 6" lift on my 4x4 project.
The shackle bushing pins are all worn out. Has anyone converted to urethane bushings and bolts like later model suspensions?
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 01-21-2012, 06:26 PM   #2
meter swinger
meter swinger's Avatar
Re: '58 Urethane spring bushing conversion?
Im assuming you mean 4x4 squarebody bushings. I think orrieg has them on his. Check his build or pm him.
meter swinger is offline   Reply With Quote
Old 01-21-2012, 06:29 PM   #3
dyno
dyno's Avatar
OR, has anyone had success bolting up 73-87 leafs and mounting brackets under the stock frame? Looks like about a 6" longer eye to eye difference on 73-87 springs front and rear.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 01-21-2012, 06:33 PM   #4
dyno
dyno's Avatar
Yes, urethane spring eye bushings like on the square body trucks. I think the eyes in the springs are probably too small for a urethane bushing after the threaded inserts are knocked out.
I'll contact Orrie and see what he's done.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 01-21-2012, 06:35 PM   #5
meter swinger
Orrie has square body leaves on his off a blazer i think. 1/2 ton bolt right up i think, but 3/4 is too wide.
