Old 01-21-2012, 03:15 AM   #1
s_nova69
Want to see what the Hotchkis rear system looks like.
I am serious about making my truck handle well. I am leaning on taking all my current suspension off to replace it with the new Hotchkis system but am wondering what the rear pieces look like.
If anyone can post a pict or two of the rear system of their installed Hotchkis system I would be appreciative.
Phil
'70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver
'72 short super build
4wd '72 Suburban LT4 coming soon!!
s_nova69 is offline   Reply With Quote
Old 01-21-2012, 09:39 AM   #2
68Stepbed
68Stepbed's Avatar
Re: Want to see what the Hotchkis rear system looks like.
http://c10forum.com/forum/showthread.php?t=8455
Some good shots of it in this thread.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-21-2012, 12:51 PM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
http://www.truckinweb.com/tech/suspe...dup/index.html
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-22-2012, 08:25 PM   #4
s_nova69
Very cool. Thanks
Phil
Old 01-23-2012, 12:37 PM   #5
Portmod7
Portmod7's Avatar
It looks like they've changed the design of the anti-squat brackets since these pictures were taken. I just tried to install mine on Saturday, and my brackets are wider, and I believe the holes are located on a radius(as they should be) instead of straight in-line with each other like in the pictures.
My brackets being wider caused a problem. There is a crease/break that runs vertical in the stock crossmember that the stock bracket sits right beside(to the outside of the bracket). Because the Hotchkis bracket is wider, it sits across that crease/break, and does not sit flush on the crossmember.
I have sent them an email, and am waiting for a reply. I suppose there's a possibility that I received a bracket for another application somehow, but I doubt it, because they provided a spacer for either side of the trailing arm to make up for the additional width when you bolt your trailing arms in.
Otherwise, it's a pretty sweet kit. The front control arms are truly a piece of art, wait until you get your hands on a set of those! I hope it feels good on the road!
Portmod7 is offline   Reply With Quote
Old 01-24-2012, 02:23 AM   #6
s_nova69
Cool. I have heard hotchkis is really good at customer service and would expect a prompt reply.
Good info though
That orange truck has me tearing my entire chassis down to bare metal and starting over.
Phil
