Torq Thrust ST's 6x5.5 (139.7)???
I have a 1970 C/10 and I really want to put Torq Thrust ST's on. Has anyone seen this done? I know I might have to run spacers and/or get longer studs...and I'll def have to get the hub machined. Has anyone done this? If so how do I get longer studs? There are also two choices +30 or +16 offset...what is my best choice? They are 20x8.5 and have a backspace of 5.5...does anyone know how bad the fitment will be??? I really like the stock power drum's so this is prob my best options...any thoughts??? Thanks in advance.
Posted via Mobile Device |
Restoration Virgin!
Re: Torq Thrust ST's 6x5.5 (139.7)???
First off...
![]() I'm not sure on the TT ST's wheels, but have seen someone use these wheels from summit...http://www.summitracing.com/search/P...=legend+wheels Member 'djmachinist' has them on his truck in his build thread here...http://67-72chevytrucks.com/vboard/s...d.php?t=388447
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
i actually had a set on my 69...no machining needed,they bolted right on.i went a different direction and used them on the wifes tahoe.
