Square body lean...
Searched for this but couldn't find much info. My 83 has the infamous lean to the gas tank side, anyone have experince with this? Suggestions on fixing it? Thanks
83 ![]() |
Re: Square body lean...
Put a shim between the leaf spring and axle perch on the low side.
Shim thickness will need to be close to (but slightly less) than the amount of the lean. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Slugish
![]() Join Date: Jan 2005
Spacer in front spring leveled mine . but would try Keiths suggestion 1st . He knows much more about this stuff than me.
I have a flip kit in the rear so if i put shim between axle and leaf spring on low side won't that make the low side worse? Would it be ok to swap the leaf springs from driver to passenger side? The difference is almost an inch from driver to passenger in the rear, haven't measured the front yet. Thanks for the help.
83 ![]() |
BAD BOW-Silverado XST
Mine has a 1" difference between the right and left side!! The gap difference is noticable when viewed from the rear. I hope to correct it with a C-notch and shims.
Mine has it too. It's normally driver's side from years of the weight of the driver as opposed to the gas tank, but I guess both could be contributors. Obviously the best fix would be new springs. I'm getting ready to try and adjust mine a bit by moving the front leaf spring hangers. Going to move the low side about 3/4 of the difference. Think that will work at least for awhile?
#7 | |
You can try the spring swap (side for side) - it might help but it may not. K
Isn't this considered the famous chevy lean?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Thanks for the help, I will try when I get time, will be starting a DD project thread soon, thanks again.
83 ![]() |
![]() Join Date: Oct 2009
My 73 c10 had that lean too. It was lower on the pass side that had the gas tank. I removed the leafs to do a flip and discovered the leafs on pass side were flattened out. I guess from the weight of the gas all these years. Went and bought leafs off a suburban at junk yard and they were the answer to my lean since subs have rear mounted gas tanks. They were exactly the same on each side. Anyhow, if you remove your leafs and set them upside down on ground you can easily check if they are the same or if one side has flattened out. Worked for me.
This might have been an isolated incident but my trucks rear passenger side leaf spring bolt had elongated the spring hanger.
"TRUCKS ARE WHAT WE'RE ALL ABOUT" 69 C-30 flatbed/dump on a '88 P30 chassis 70 C-30 Cab & Chassis http://67-72chevytrucks.com/vboard/s...d.php?t=291544 67 GMC Camper Cruiser cab 73 Gmc K25 Sierra Grande BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=291276 |
Alright Alright Alright
Where do you find shims for the front coils?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
Spear and magic helmet!
I had a lean, but got real close to level by swapping my leafs in the rear side to side. Passenger side was noticeably higher than the driver side.
Pep Boys sells coil spring spacers, if you're going that route. |
I did a flip, bought new shocks, coils, spindles, all that jazz. I just decided to get new leafs while I was at it to correct my lean. Everything else was replaced, whats another 226 bucks lol. Im putting a center mounted fuel cell in mine though to help with getting gas every 2 days and hopefully prevent lean later on. That lean was annoying though
#15 |
mine has a lean, but feels to me like its on the front. i blamed it on myself. when doing the 5.3 swap, i moved the battery to the drivers side so i could use the 04 air cleaner and tubing.
