Old 02-06-2012, 12:52 AM   #1
welderboy
new here with T 5 speed /GMC V6 question
Newbee wondering if there is a thread on anything related to the V6 GMC and the T5 5speed tranny? Thanks
welderboy is offline   Reply With Quote
Old 02-06-2012, 09:27 AM   #2
duallyjams
duallyjams's Avatar
Re: new here with T 5 speed /GMC V6 question
I have seen threads about that over at http://www.6066gmcguy.org/
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-06-2012, 10:33 AM   #3
jbgroby
jbgroby's Avatar
If you're mating a T-5 to a V-6, you'll need to have the automatic adaptor plate, either from the factory or buy one from Bendtsen's transdmission adaptors
http://www.transmissionadapters.com/
jbgroby is offline   Reply With Quote
Old 02-06-2012, 11:12 AM   #4
welderboy
Can not seem to join the group at 60-66 gmc guy, the Yahoo stuff has me stumped. Was hoping there was a way to use the bellhousing that came with the truck as it has a 4speed. Has any one created a thread on doing this?
Old 02-06-2012, 12:31 PM   #5
slorio
slorio's Avatar
Welderboy:
T-5 swaps have been written up pretty extensively on the inliners.org website. Also, you can do a search here and find some nice write-ups.
T-5 isn't a very strong tranny. Behind a GMC V-6 you will have problems with it self destructing, if you don't take it easy on it.
Basically, you can either cut down the bearing retainer and input shaft on your T-5 or buy an adapter/spacer so that the larger bearing retainer on your T-5 will fit the smaller diameter hole in your bellhousing. The T-5's from S-10's tend to have the best placement of the shifter for trucks. The T5's from Firebirds and Camaro's have the shifter on the back of the tailshaft which would hit the seat in your truck if you are using the bench.
Hope this helps.
regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 02-06-2012, 10:22 PM   #6
welderboy
Steve, Thanks. Do you have any other ideas? I would like to use the truck for work (not hotrodding) but it really is tached out at about 55 mph. What kind of mileage can i expect from the 305 V6. Thanks
Old 02-06-2012, 11:36 PM   #7
slorio
slorio's Avatar
Welderboy:
The V6's aren't known for good gas mileage. They are torquey and have great longevity. The good news is that makes them easily able to handle taller gears. Do you know what rear end ratio you have? You can change ring and pinion to make them taller, increase rear tire diameter or go with an overdrive to slow down RPM's on the highway.
My truck has 3.54 rear end and I went with a 3 speed with overdrive. I think it is a great addition and an easy swap. When the tranny shifts to overdrive, it reduces the RPM's by 30% since the overdrive is .7 to 1. We have a writeup on them currently going at:
http://67-72chevytrucks.com/vboard/s...d.php?t=506747
I put some references on there where you can read all about them. Also, the search function on this board will bring you a lot more reading.
See if that is of interest.
Regards,
Steve
New Orleans
Old 02-06-2012, 11:46 PM   #8
jbgroby
jbgroby's Avatar
Welder,
I have made some mods to my ride in the following manner
changed the oem rearend from stock down to 3.23 MAde a world of diff. not longer hitting 3000prm at 70 mph 2300 at 70.
changed out the single barl. carb to a 500 cfm holley (You may need to change the intake though.)
Check my webshots album for the various chages I've made.
JAke
