Old 02-06-2012, 09:29 AM   #1
63CHEVY62GMC
63CHEVY62GMC's Avatar
Question Vent window question
the vent window on my 63 chevy truck is loose and wont stay open, and i was wondering if there was a way to tighten it back up. any help is appreciated
1998 chevy silverado- weekend and long trip truck
1963 chevy c-20 (black betty)- daily driver
1962 GMC wrecker- ongoing project that will never be finished
63CHEVY62GMC is offline   Reply With Quote
Old 02-06-2012, 10:28 AM   #2
jbgroby
jbgroby's Avatar
Re: Vent window question
Remove the door panel, look in there and see if you can reach the adjusting nut at the bottom of the mount post, The used a winged washer, it has two ears on it you'll need to bend out of the way to get your socket on it. PITA with out removing the wholw assembly.
Of course it a PITA to removed the whole assembly too, so we're messed up both ways - go figure
jbgroby is offline   Reply With Quote
Old 02-06-2012, 12:56 PM   #3
63CHEVY62GMC
thanks jbgroby, ill try that in auto shop class
Old 02-06-2012, 01:43 PM   #4
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Funny I just had to replace the rubber and felts and one side of glass. Not hard to do but again the LMC rivits sucked, way too long the tool is made out of something so soft that even a brass hammer mushroomed the tool into a mess. If I had to do it over I would have used urathane to attach the inner sealing rubber, I did rivit one side and used pop rivits on the other for the outer glass frame. Worked great, the LMC sash kit is a waste of time, it has no holes in it , nor does it have the counter sunk areas for the rivits to go into, and they have velcro ( fuzzy side) shoved into the un drilled channel.
GMR-PERFORMANCE is offline   Reply With Quote
Old 02-06-2012, 05:50 PM   #5
McCoyAZ
McCoyAZ's Avatar
That's why I want to take the wing windows out and put in one oiece electric windows.
Just need to save about a grand b4 I can have it done.
McCoyAZ is offline   Reply With Quote
Old 02-06-2012, 06:11 PM   #6
hopped up
hopped up's Avatar
but they look soo much better with the wing windows!!
hopped up is offline   Reply With Quote
Old 02-06-2012, 06:29 PM   #7
MisterC
MisterC's Avatar
I haven't done it yet but I've researched it. I manage an airport with a very active experimental aircraft association. Those guys press rivets all day long and have the right tools for the job. I've had a couple of my tenants look at them and they say those rivets are cake with the proper tooling.
If you live close to an airport, remove the assembly and go talk to one of those guys. They love doing stuff like that.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 02-06-2012, 07:48 PM   #8
GMR-PERFORMANCE
You are correct I have tons of gear for buc rivits but not for these steel center versions. Really steel pop rivits will hold even better than the rivits, and there is enough room in them for the window to slide up and down. I just put mine together and they work fine one side has has pop and the other the peen over style. The rivits that came in the kit where way too long, I had to shorten them a bit. Just a case of a company selling a one size fits all part.
