Old 02-20-2012, 11:35 AM   #1
62 Barnfind
62 Barnfind's Avatar
Front right cab mount
What is the best way to replace the front cab mount bracket? The cab is still mounted on the frame. I think the floor is spot welded to the cab mount. I know I will figure it out but someone who has done it with the cab on would help it go faster. Here is the mount I am talking about.
62 Barnfind is offline   Reply With Quote
Old 02-20-2012, 12:52 PM   #2
k1rodeoboater
Re: Front right cab mount
You pretty much got it. Cut the metal back till you hit healthy stuff. Or you can replace the full thing. Based on what I am seeing I would do the full support. My rule is less than 50% I patch and fix. Greater than that I replace with as full of a piece as I can.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
