Old 08-15-2011, 11:19 AM   #1
72tutone
How would you fix this?
Please *note* I am just jumping into the frey with doing body work and welding etc.. I literally bought 125ez welder hobart not that long ago and have been doing some "practice" with it, so I am by no means a guru.
Looking at my rear window here. How would you fix this? Sand down? body filler to follow?
Thanks for the suggestions and sorry for my lack of inexperience.
72tutone is offline   Reply With Quote
Old 08-15-2011, 12:03 PM   #2
mbgmike
Re: How would you fix this?
probably will get moved to the paint and body section.
I would sand blast it and weld in any patches needed. if you can't make them send us dims needed and we can fab and send them to you.
if they are just pitted after blasting and no holes blown through I would fill them in with allmetal
mbgmike is offline   Reply With Quote
Old 08-15-2011, 12:11 PM   #3
Ackattack
Ackattack's Avatar
I had similar damage on my truck. I cleaned it up with a wire wheel, cut out and replaced the holes. Filled in with weld over some of the thinned area, then grinded it smooth, then let the body man take care of the rest.
Ackattack is offline   Reply With Quote
Old 08-15-2011, 02:24 PM   #4
treveiger
treveiger's Avatar
When you cut it out spray some rust converter in areas you can't get to. I forgot the name of the rust converter but it starts with a p lol. Itll stop the rust from growing an spreading. But welding patch panels where the rust is bad is a good idea instead of bondoing the holes.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 08-15-2011, 08:26 PM   #5
newagecustom
c10 Chop Artist
newagecustom's Avatar
Originally Posted by treveiger View Post
when you cut it out spray some rust converter in areas you can't get to. I forgot the name of the rust converter but it starts with a p lol. Itll stop the rust from growing an spreading. But welding patch panels where the rust is bad is a good idea instead of bondoing the holes.
posted via mobile device
por 15
newagecustom is offline   Reply With Quote
Old 08-15-2011, 08:29 PM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
just chop it
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-15-2011, 08:30 PM   #7
Steve Hafner
Steve Hafner's Avatar
Talking Re: How would you fix this?
" You'll be able to buff that out . . . no problem " !!!
Life is short . . . we only have, right now.
My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526
Steve Hafner is offline   Reply With Quote
Old 08-15-2011, 11:12 PM   #8
treveiger
treveiger's Avatar
Originally Posted by newagecustom View Post
por 15
No Picklex-20 is the name, I've heard mixed things about por 15 but never used it myself
Old 05-07-2012, 05:58 PM   #9
72tutone
Does anyone sell any patch panels for the lower rear window
I know mbgmike stated that he can fab some up and I might have to go that route depending on if no one sells them.
Any ideas?
