Old 02-24-2012, 04:07 AM   #1
moggey01
Aluminum body mount bushings on a C/10
I have heard of people using an aluminum bushing but I cant find any anywhere. Are people using Camaro, or Nova ,Chevelle body mount bushings ?? What has to be changed if anything?
moggey01 is offline   Reply With Quote
Old 02-24-2012, 12:14 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Aluminum body mount bushings on a C/10
I never heard of such a thing but it depends on your definition of "body mount bushings". Body mount bushings are either rubber or poly and are designed to absorb vibration and road shock. Some people refer to the metal sleeves/spacers that go inside the rubber or poly bushings as bushings but I don't think that is correct. A picture of what you are referring to or replacing would be helpful.
LockDoc
Leon
Old 02-24-2012, 03:17 PM   #3
cdowns
cdowns's Avatar
ultra performance cars have them but not really suitable for a street driven vehicle// as it is the poly bushings are plenty rigid and transfer enough vibration and noise to the cab that i've seen a bunch of guys dump the poly andd go back to the original rubber in a short period of time
Old 02-25-2012, 01:48 AM   #4
OldCreek
OldCreek's Avatar
Offroad designs, ord, sells 1" body pucks if you are so inclined...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-25-2012, 03:03 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
I have a set on my K5... They are spacers, not bushings. Bushings are two pieces that are stepped to fit together...
Rich
1972 K5 Blazer CST Click HERE
Old 02-25-2012, 08:25 AM   #6
moggey01
Ummmm, what I was asking about was a ''Body mount bushing" . Global west calls them bushings so I guess I will also. I was looking for aluminum for a reason, not for a vibration free ride. There are several people that have them but not for a truck, that is why I asked about a crossover part. Thanks
Old 02-25-2012, 08:54 AM   #7
71 super
71 super's Avatar
typically they are used on race cars for better transfer of weight etc. If you are wanting to use them i would take my old bushings and have a machine shop create them for you. As stated earlier it will be super rigid, but if you are looking to transfer weight and eliminate body flex this is the way to go.I think a quality poly will work fine (went down this road a long time ago)because the minimal transfer/flex reduction will be countered by the lack of weight in the rear.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 02-25-2012, 11:04 AM   #8
moggey01
yep, I plan on doing some racing LOL
Old 02-26-2012, 01:09 PM   #9
CG
BlahBlahBlah
DIY4x4 has one inch aluminum body pucks that might work for you.
http://diy4x.com/cart/index.php?rout...product_id=174
