Old 03-16-2012, 01:06 AM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I need some tire size help please....
I don't want to beat a dead horse here, but I'm racking my brain out trying to figure out what tire size I can use on my '69 C/20 8-lug stock ride height. I would like to try the H2 Hummer rims, but don't know how to figure out what tire size I can go with. I'd like to run a bigger tire like 285/70-17, which is almost the same size as a 285/75-16 (which I see many have used). I want to be sure they will fit without any clearance problems on the H2 rims. I was thinking about trying to find some junk tires to mount and try, but I don't really want to mount and unmount tires on these nice rims if I don't have too. Is there anyone out there that can help me?
I'm not sure how stock wheels compare to the H2 wheels, but I've heard they have more backspacing. Here is what I've learned so far about the H2 wheels:
17" Dia.
8-lug X 6.5" BC
4-1/2" Hub Dia.
8-1/2" width (9-3/4" overall rim width)
5-1/2" Backspace which translates to 3/4" (19 mm) positive offset
BTW, I purchased OEM Chevy 16" center caps P/N 9597169 / 9597170 which are 2001-2007. They fit perfectly on the H2 rims with no mods required. I also bought the correct conversion lug nuts.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-16-2012, 01:54 AM   #2
PAWS 72
PAWS 72's Avatar
Re: I need some tire size help please....
Please try to find the white lettered tires and mount letters out.
PAWS 72 is offline   Reply With Quote
Old 03-16-2012, 06:55 PM   #3
derotoreut
derotoreut's Avatar
I need to know what size tires will fit on these rims first without having a clearance problem. Anyone know how big I could go on these rims?
~ Dan
Old 03-16-2012, 09:08 PM   #4
Sideways
Sideways's Avatar
I think 275-70 should clear fine if you can get them.
Sideways is offline   Reply With Quote
