Old 07-16-2007, 07:12 AM   #1
67dragtruck
67dragtruck's Avatar
bed lift?
I know I have seen one on trucks tv before that let you use a engine hoist to lift a truck bed so you could remove/install by yourself. Anybody know where I can buy one or who makes one?
Thanks,
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 07-16-2007, 09:01 AM   #2
cdowns
cdowns's Avatar
Re: bed lift?
most people that i know just figured it out and built them
Old 07-16-2007, 11:21 AM   #3
wibilly
wibilly's Avatar
Re: bed lift?
very easy to buid your own. i don't think it took 20 min to throw togather mine with some scrap i had laying around
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 07-16-2007, 11:52 AM   #4
Big D
Big D's Avatar
Re: bed lift?
I just built mine out of some unistrut I had laying around. I used 2 pieces that fit snug under the rails, then one about 5 feet long to tie them together.
It worked great, After I lifted the bed I reconfigured the unistrut to lift the cab off. I'll try to get a pic of the setup I used if your interested.
68 GMC
64 1/2 Mustang convert
A bachelor's life is no life for a single man."
- Samuel Goldwyn
Big D is offline   Reply With Quote
Old 07-16-2007, 11:54 AM   #5
nplocoman
never finish start another
nplocoman's Avatar
Re: bed lift?
Please post apic Thanks
nplocoman is offline   Reply With Quote
Old 07-16-2007, 12:24 PM   #6
Rokcrln
Rokcrln's Avatar
Re: bed lift?
I sell plans to build a bed/cab lift that folds up for easy storage. See my sig for info. It also uses the engine lift. And it is so easy that your wife can do it while pregnint!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 07-16-2007, 02:09 PM   #7
Big D
Big D's Avatar
Re: bed lift?
Here is a pic of my lift in the cab lift configuration. I used the L brackets to bolt to the end of the engine lift whre the chain bolt resides.
For the bed lift I just used a 5 foot piece for the center piece with grade 8 7/16th eye bolt. I also used all grade 8 3/8 bolts to boly the steel together.
The end pieces pictured were added to keep the cab from shifting while up in the air. It worked great, I was a little nervous lifting the cab that high in the air ( it was going on a 3/4 4x4 chassis)
If your not familar with unistrut, its available at electrical supply houses and I have seen it at Home Depot. Its runs around 10 bucks for a 10 foot piece.
68 GMC
- Samuel Goldwyn
Old 03-09-2012, 10:00 PM   #8
elf w/capital T
Re: bed lift?
money
elf w/capital T is offline   Reply With Quote
Old 03-09-2012, 11:50 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: bed lift?
a 12 pack and a Pizza is an acceptable cab or bed lift also.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
