Old 03-15-2012, 01:07 AM   #1
c1069
c1069's Avatar
cab dimension HELP
I need to know what is the measure from lip to lip
I stole this picture from ( BucksSS )
Pancho
69 c/10 step side 454/400 with 3.07
c1069 is offline   Reply With Quote
Old 03-15-2012, 10:46 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: cab dimension HELP
My 68 GMC shows 35¼ inches. Should be the same as others but I have a stripped out cab from my old 69 Chevy in another location and can get that later this week if someone else doesn't have a confirmation for you.
68gmsee is offline   Reply With Quote
Old 03-15-2012, 12:43 PM   #3
old Chevy guy
old Chevy guy's Avatar
That sounds right. I took that measurment before I cut the floor and rocker out of my cab. I will double check but I think thats good.I'll repost if I find something diffrent.
old Chevy guy is offline   Reply With Quote
Old 03-15-2012, 05:22 PM   #4
c1069
c1069's Avatar
In my cab driver side have 34 2/8 [1/4] and pass side 34 3/8 is a big gap in my pass side. I think that is the problem.
Here are some pictures from my can and I welded all corners before take off the whole floor.
Pancho
Old 03-15-2012, 07:47 PM   #5
old Chevy guy
Yea I went and measured my cab again and it was really 34 and a scant 1/4. Like I said before I measured it before I cut anything out and this cab was pretty tight when I got it.
Old 03-15-2012, 07:50 PM   #6
c1069
c1069's Avatar
Thanks guys for your support.
Pancho
Old 03-15-2012, 07:59 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Just for the heck of it I measured more towards the bottom from where I checked this morning and it's 34 5/8 inch. So I guess the measurement is going to differ slightly depending on where you measure.
