![]() Join Date: Jul 2011
AC wiring Question - Name this plug.
![]() Getting the AC ready and got everything working up to this plug. I know this plug got to the AC system but what do the two connections go to. One is a long leg and one is a short leg. When should they connect too? Also, is there polarity on the compressor? for it matter which is + and which is -? Thanks in advance
85 Silverado SWB |
Re: AC wiring Question - Name this plug.
I believe that connects to wiring harness that comes from the compressor. Some will correct me if I am wrong.
Life is to short to drive anything else ![]() |
I think so also. Both the connections on the plug are hot too.
85 Silverado SWB |
I'd like to know this too. Mine has nothing on it either, but I don't use my A/C.
Moderator
![]() Join Date: Oct 2008
Dark Green is power to the AC clutch through the pressure cutoff.
Light Green is power for the throttle solenoid. It kicks the idle up to keep the AC load from stalling the engine. What I don't see is the second green wire that runs from the connector through the firewall to the heater control. Probably the camera angle. |
#6 | |
Moderator
No. Just the schematic for the AC subsystem.
