Old 04-07-2012, 09:24 PM   #1
SRVBLUES64
I need engine help
I have a 350 in my 66 chevy truck it seemed to be laying down when accelerated or put into gear. this is what we have done, vacuum checked perfect all electrical checked paerfect distri and other ohms that you can check. I even put a new hei accel dizzy on we timed it with a light but its just keeps laying down Im thinking timing chain gears they are new but that the only thing I can thing of now any thoughts any one before I rip it a part to look at the gears??????
SRVBLUES64 is offline   Reply With Quote
Old 04-07-2012, 09:56 PM   #2
Lower
Lower's Avatar
Re: I need engine help
Checked the fuel filter and cleaned the carb?
~Jon
Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 04-07-2012, 10:17 PM   #3
Big Fenders
Possibly carburation...accelator pump comes to mind...
Bob
Big Fenders is offline   Reply With Quote
Old 04-07-2012, 10:24 PM   #4
scotts62
One day...
scotts62's Avatar
Is it stock or just start all of a sudden? I think of my truck when i put dual carbs and huge cam in it and i had to put a stall converter in it so it would move, that comes to mind to me
Scott
93 crew cab build
Project 62
Old 04-07-2012, 11:06 PM   #5
S-31
Sounds like accelerator pump going bad in the carb to me. Bump the timing up 2-4 deg and see if it gets better.
S-31 is offline   Reply With Quote
Old 04-08-2012, 03:20 AM   #6
SRVBLUES64
Thanks guys I have a brand new 570 avenger in it, I just got the engine running about a week ago sounds great till in gear, I did use my old tank and it seems to have enough gas through it Im thinking timing chain maybe a tooth off?
Old 04-08-2012, 07:42 AM   #7
tincan1966
tincan1966's Avatar
If the truck was an original 6 cyl, the fuel line is only 5/16", could be starving a bit for fuel volume.
Also a new carb doesn't mean it's a good one-it happens.
Sounds to me more like a fuel problem, not a major mechanical thing.Is the vac advance on a ported or timed vac port on the carb?
tincan1966 is offline   Reply With Quote
Old 04-08-2012, 08:38 AM   #8
SRVBLUES64
all lines are correct and vacs at 14+ it seems that fuel is the problem it runs and idles great but once in gear and I power brake it or lunge forward it dies
Old 04-08-2012, 08:47 AM   #9
Wootdog
Wootdog's Avatar
For troubleshooting purposes, I would install a see thru fuel filter in line. You can then visibly see if the fuel volume goes down when you put it in gear. It will take two people to do this.
Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 04-08-2012, 08:56 AM   #10
fasteddie1964
fasteddie1964's Avatar
If you're using the old tank better put a filter between tank and fuel pump. This is what I collected using new tank just in the line from tank to fuel pump.
Friends don't let friends drive Fords
fasteddie1964 is offline   Reply With Quote
Old 04-08-2012, 09:59 AM   #11
198plus
198plus's Avatar
What do you have the initial timing set at ?????
198plus is offline   Reply With Quote
Old 04-08-2012, 07:45 PM   #12
SRVBLUES64
timing at 14 without vac total was 43 we did check the timing gears and it dead on, so we put it all back together and I bought a clear gas filter and I took the lines off and pour the gas in a glass and we got sediment not much but we also got rust. I took the carb a part and cleaned everything and blew it out, I think that the fuel maybe my problem. I hope
Old 04-08-2012, 07:46 PM   #13
SRVBLUES64
Im looking at a new tank!
Old 04-08-2012, 08:05 PM   #14
brokenspoke
brokenspoke's Avatar
Good idea
brokenspoke is offline   Reply With Quote
Old 04-08-2012, 08:46 PM   #15
awbrown
I would agree with accelerator pump...the minute you move the throttle it should be spraying fuel from the pump shooter..... it may have a plugged channel or the rubber on the pump itself is hard and not sealing in the well.....
awbrown is offline   Reply With Quote
