Old 03-26-2012, 09:29 PM   #1
rmvlt1100
rmvlt1100's Avatar
Exclamation Relocating my front shocks.
I need some info on relocating my front shocks. I have a 1965 C-10 that I am installing air bags on. I was told that it was a good idea to relocate my front shock mount a little higher,so my questions is; Which one should I use? I have searched through the internet and this forum and seen numerous one from POL, CPP, Ride Tech and others. So if some one can help me out again that would be great. Thanks in advance.
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 03-26-2012, 11:29 PM   #2
SCOTI
SCOTI's Avatar
Re: Relocating my front shocks.
POL offers a simple bolt-on upper shock bracket that allows for more travel using factory replacement (C10) shocks. Cheapest/simplest option....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-26-2012, 11:47 PM   #3
SCOTI
SCOTI's Avatar
Ride Tech offers a universal upper shock relocation bracket/tower that's a 'weld-on' deal but it can be modified & welded to a bolt-on bracket. More work but easier to optimize per your specific build requirements....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-26-2012, 11:48 PM   #4
SCOTI
SCOTI's Avatar
Hotchkis has a nice front shock kit w/Hotchkis tuned Bilsteins & relocation brackets for better geometry. Their stuff is intended for coil apps but does offer greater travel & would still work better than OE shock mounting. Most expensive option but very high quality shocks & significant R&D focus on shock performance....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-27-2012, 06:47 AM   #5
rmvlt1100
rmvlt1100's Avatar
Scoti, Thanks for the response and the options. I think th POL is the one I will try. The Hotchkis one is a little expensive and the Ride Tech one looks like you need to work around the inner fender. Again thanks for the help.
Old 03-29-2012, 06:32 PM   #6
michael bustamante
michael bustamante's Avatar
check out ECE shock relocators also.
1967custom
michael bustamante is offline   Reply With Quote
Old 03-29-2012, 08:06 PM   #7
SCOTI
SCOTI's Avatar
I've never seen any ECE front shock relocators??
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-30-2012, 01:52 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Junkyard option. A 4wd chevy with dual shocks, the second shock bracket is pretty neat.
Old 03-31-2012, 02:14 PM   #9
SBTork
Garage wrench
SBTork's Avatar
Not to get too far off topic, I wonder if these would work on the 73-87 trucks. They look like they would, but I see they're listed for only 63-72. Anyone have any input?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 03-31-2012, 10:16 PM   #10
SCOTI
SCOTI's Avatar
They would; but would require trimming the inner wheel well (you can see how close it comes to the top of the frame in the 1st pic). That being said, 73-87's are slightly taller in the shock area & can utilize a cheap homemade relocator out of 2" square .250" wall tube.
The last pic is from Ride Tech. It's similar in function....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-01-2012, 10:30 PM   #11
rmvlt1100
rmvlt1100's Avatar
Thanks to everyone for the input. I ordered the ones from POL and should be here Wednesday.
Old 04-04-2012, 06:49 PM   #12
SBTork
Garage wrench
SBTork's Avatar
Awesome, thanks for the ideas!
-Adam
