Under construction!
Well, I tend to skip around when working on my truck. I thought it would be a good idea to make a plan and stick with it. My problem is debating when I should have the interior re-painted...!?! Anyway, tell me what you think.
![]() Truck Build-up Guide The following is a simple and basic overview of my truck build-up sequence. Rear Suspension---Being that I already have ART’s parallel 4-link and FBI step notch, I’m going to finish the back. Once those components are installed and I can manually inflate the air springs---I’ll purchase the front Cool-Ride kit. Drivetrain---I’ll remove the engine, transmission, and everything in the engine bay. Bodywork---I’ll remove the inner wheel-houses, fenders, and entire radiator support. Front Suspension---After the suspension has been removed, I’ll paint the frame and cross-member. Once the PST bushings are installed, I’ll paint the control arms and other components. Next, I’ll install the suspension and replace miscellaneous parts as needed (Wheel bearings, etc.) Bodywork 2---I want to shave/smooth the firewall and paint it the color of my choice. Cameron Park Auto Body or Lonnie and myself may complete this step. Drivetrain 2---Henry and I will install a factory replacement GM 350 crate motor. Prior to installation, I’ll paint the engine and transmission. This step will only involve installing the actual engine, not the accessories. Interior---I’ll remove the entire interior. Bodywork 3---I’ll have bodywork completed in the following stages: 1. Cab 2. Front end 3. Bed At this time, I am not sure what modifications will be done. Drivetrain 3---After the front end has been bolted-up, I’ll install all engine accessories. During this step, I’ll also organize and detail the engine bay. Interior---??? Wheels and Tires---I plan on running a 20/22” wheel combination with low-profile tires. Braking System---I plan on purchasing a rear disc brake conversion kit, front upgrade kit, and new proportioning valve from SBC. That’s it for now and I’ll see how my plan works out.
2001 Silverado bagged on 22's. *Sold* |
