Old 04-15-2012, 11:56 AM   #1
IB4BAMA
IB4BAMA's Avatar
Question Lowering a 1987 Silverado?
I've got a bone stock 1987 Chevy Silverado LWB. I just installed a new set of KYB Mono Max shocks. I want to level the back with a set of shackles and maybe the front, not radical just a smidge. How low can I go without changing the shocks? If 2'' drop shackles is about all it will stand, what brand would y'all recommend and what can I except as far as ride? I will be pulling a good size bass boat at times so that might change things all together.
I use heavy strings, tune low, play hard and floor it. Floor it, That's technical talk.
~ Stevie Ray Vaughan ~
IB4BAMA is offline   Reply With Quote
Old 04-16-2012, 10:25 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Lowering a 1987 Silverado?
You should be fine with those stock shocks and a shackle. You will need to check your rear spring length to determine if your going to have to cut the bed brace to clear.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-16-2012, 06:26 PM   #3
IB4BAMA
IB4BAMA's Avatar
