Old 04-18-2012, 11:29 AM   #1
rideblue00
rideblue00's Avatar
Std gauges to Deulxe question
I have a 6cyl with the idiot lights. I want to change to the deluxe gauge cluster. Can i just plug my deluxe harness into my std harness. Will i have to get the correct sensors or are they the same? I obviously will have to run a hard line for the oil pressure gauge.
rideblue00 is offline   Reply With Quote
Old 04-18-2012, 11:47 AM   #2
1963c-10
1963c-10's Avatar
Re: Std gauges to Deulxe question
The main underdash harness and engine harness are completely different. You cannot just plug in the new cluster. The ammeter has to be wired, the temp guage goes from 2 wires to one, the oil line has to be plumbed. The only plug that is the same is the fuel guage. You also have to replace the temp sending unit from warning light to guage. You have to get rid of the oil sending unit and just plumb the line in.
1964 Short bed trailer
Old 04-18-2012, 11:57 AM   #3
rideblue00
rideblue00's Avatar
Thats what i was looking for. Thanks
Old 04-18-2012, 01:19 PM   #4
1963c-10
1963c-10's Avatar
You can modify the original harness to work, as long as you make the modifications mentioned above. I did the conversion myself, but the PO hacked up the wiring pretty good so I replaced all the wiring which made my conversion a little easier, although more expensive.
