IRS anyone?
I just stumbled across this complete Mark VIII IRS and wanted some opinions on possibly throwing it under an 86 SWB with airbags. I believe it's 63" rotor to rotor (wheel mounting surface). I've seen they got an install kit for 73-87's here http://team321.com/truckirs/truckirs.html
As you can see in the pics, I have the entire assembly with the subframe. The IRS had factory airbags with an 8.8 aluminum center section, aluminum lower control arms, disc brakes and a rear sway bar. I'd love to hear some input/opinions on this rear setup... good, bad or ugly ![]() ![]() ![]() ![]() ![]() Underside Shot ![]()
Joe Last edited by chevychase; 04-08-2012 at 04:49 PM. |
Re: IRS anyone?
It's heavy. But in the right area. You cannot haul a load again. And the rear diff and axle I imagine are weaker
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Truck Junkie
![]() Join Date: Aug 2008
Re: IRS anyone?
I've been looking at the same swap. I think Porterbuilt has a kit for this swap. Trucks has a build on a ranger with type of rear end.
Posted via Mobile Device |
Re: IRS anyone?
Porterbuilt has a c4 kit,Coming from a mark 8 owner pass on it and sell it.That irs is the weakest one ford made the cobra mustang is a copy but beefed up.
![]() Join Date: Jul 2010
Re: IRS anyone?
Go for it..it would be a cool swap..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
Re: IRS anyone?
Thanks for all the input. I've seen a few trucks with an IRS browsing around so when I seen this cheap I just grabbed it for the heck of it.
Joe |
![]() Join Date: Nov 2003
Re: IRS anyone?
It doesn't look like you installed it right to me. I am pretty sure it goes the other way, and it's supposed to be under the bed.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#8 | |
Re: IRS anyone?
Joe |
Re: IRS anyone?
Other than it being Ford parts.... I think it would be a cool idea.
Re: IRS anyone?
If you do go through with it get the diff cover brace and the solid front diff mounts that will toughen it up enough.
A day should have 30 hours.
Re: IRS anyone?
There is a company in BC that is developing a bolt in IRS for our trucks.
I'll look for their contact info. |
Re: IRS anyone?
Good point, I've seen those mentioned in my recent research.
Joe |
Re: IRS anyone?
Sounds cool... I'm here!
Joe |
![]() Join Date: Mar 2005
Re: IRS anyone?
Pretty interesting. I can see pros and cons with that set-up, but I see much more good than bad. It looks heavy, but if you spent some time eliminating the un-needed stuff, fully welding the seams on the framework, and sanding the excess flash and bumps off the lower control arms, it could look pretty cool. Question: I assume that this suspension uses an airbag from the factory? I don't see an area to mount a shock, but that's an easy fix.
The 8.8 rear differential is pretty tough, and there are vendors making nice aftermarkets parts for them. You're going to have to decide what level you want to take the truck to. This set-up is going to cost more money in the end, and could compromise your ability to haul anything. It's also going to be hidden under the bed floor, and all that chassis work won't be visible. On the plus side, it should handle better, stop better, and if you install it up high in the chassis, the truck will be really low and have full suspension travel.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#15 | |
Re: IRS anyone?
Joe |
#16 |
Re: IRS anyone?
Take a look at http://www.supercoupeperformance.com...px?category=79 they have all the upgradeable pieces
#17 | |
Re: IRS anyone?
Joe |
#18 |
Re: IRS anyone?
I love my mark 8 its almost a mustang cobra with a luxury car dropped over it.
#19 |
Re: IRS anyone?
Get ready for plenty of wheel hop. I installed a 93 mark 8 IRS in my 67 F100 when and eventually sold the entire chassis due to terrible wheel hop, then again I guess a twin turbo diesel didn't help matters lol.
