Old 05-10-2003, 10:41 PM   #1
popdad
Unhappy truck wouldnt start
hi guys went out to start truck its cold here and it wouldnt start it was fine when i parked it no spark finnaly changed the mod and it fired right up first time that has happened had me wondering cause every thing was new only thing i changed was the coil put in a hotter one last week do you have to put in some different modual when you change coil or is stock ok or is it just a thing cause it was cold the mod was only less than ayear old just wandering if you guys had that happen or you would know if i had to buy a different mod thanks popdad
popdad is offline   Reply With Quote
Old 05-10-2003, 11:04 PM   #2
popdad
mod
it seemed like it had plenty on it when i redone the motor i had a seal out in the distrib cleaned it up but maybe it washed some of it out or it was a time for it to go popdad
Old 05-11-2003, 04:07 AM   #3
jimfulco
Coil & module should match. Get a module made for that coil by that manufacturer. Use the new grease.
jimfulco is offline   Reply With Quote
