Old 05-29-2012, 11:50 PM   #1
RexDodge
WTB 8 inches of 2" rubber fuel neck
I refuse to fund the local u pull yards as they mostly have been bought up by a steel scrapper corporation (prices nearly doubled). I need 8" to a foot of rubber fuel filler neck/hose to complete my fuel tank conversion. Anybody have a scrap left over they want to sell?
RexDodge is offline   Reply With Quote
Old 05-30-2012, 01:44 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: WTB 8 inches of 2" rubber fuel neck
a marine shop will have what you need if you have no luck here.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-30-2012, 10:17 AM   #3
RexDodge
Never thought of that! The local parts stores only sell it in 3' minimum lengths. Thanks for the tip!
Old 05-30-2012, 10:24 AM   #4
vectorit
What?
vectorit's Avatar
Check around your area for an industrial hose supply house.
I buy mine from a local shop that caters to forklifts and big rigs, and they have a huge supply of all grades of hose.
In case you can't find anything in your area, perhaps you can mail order what you need from the place I go to.
www.hose-man.com
I will look around for the exact ID size for you, I have a picture of the hose I use around here someplace.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 05-30-2012, 11:51 AM   #5
botmfedr1
botmfedr1's Avatar
I went to NAPA (the real parts store) and i got the exact same 2" hose that was on my Suburban. It happened to be a coolant hose according to the description. It was used as the fuel hose because it doesn't have a constant presence of fuel running thru it. When i spoke to the original owner of the suburban i bought, he told me that hose had been in place for about 12 years. The only reason i took it off was to swap bodies and the hose wouldn't come off. It was still very pliable and no cracks or anything wrong with it.
I tried the other parts stores, and they either didn't have the exact same size hose. And the closest size they had would only sell it in 3' lenghts.
Try NAPA!
botmfedr1 is offline   Reply With Quote
