Old 09-05-2006, 10:11 AM   #1
bretcopsey
1951 Project underway
Hello,
I joined quite a while ago to ask a question about a potential project. What I was told was a 52 GMC turned out to be a 51 Chevy when I looked at it. Being up for a challenge, I took it anyway.
Here's a couple pictures. You can see more at the link below.
http://www.cardomain.com/ride/2285825
bretcopsey is offline   Reply With Quote
Old 09-05-2006, 06:02 PM   #2
Jebb1978
Jebb1978's Avatar
Re: 1951 Project underway
You are an ambitious guy, that's for sure. Great progress so far, keep up the good work!
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 09-05-2006, 06:45 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Whats the acid treatment your using?
Old 09-06-2006, 12:05 AM   #4
bretcopsey
I'm using phosphorioc acid, which is a generally accepted method of removing rust. The unconventional part is that rather than use 'Naval Jelly' or 'Ospho' which are both somewhat expensive, I have found that a tile/shower cleaner sold under the Zep brand name at Home Depot works great, and is only $6.88 a gallon.
My 51 project
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
Old 09-06-2006, 08:57 AM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
After first seeing all that rust I didn't think you'd be able to save much of that. But that dip works great. Do you dilute it or straight? and will it run thru a pump so you can shower a part?
Old 09-06-2006, 09:47 AM   #6
bretcopsey
I have diluted it quite a bit. The large tub seen in the radiator support picture is one of the ones I have used, filled mostly with water and experimenting with the amount of acid. I think that is a 30 gallon tub, and I had about 2 gallons of acid in it.
I have also tried using a submersible pump to shower a part, but my pump flow is too great. I need to find a way to reduce the flow. Since I haven't done this long term, I don't know what the effects of running acid through the pump would be. Hopefully it won't be eaten from the inside out!
As for the rust on this truck, the majority of it is actually surface rust only. There is very little that is severe rot. As an example, if you look at the pass side door in the picture above, most of what you see that is brown is actually just stained paint or primer. Only the darker patches are surface rust. This truck had a plate on the front from South Dakota dated 1962!! It has just sat in the weather for many years.
My 51 project
Old 09-07-2006, 01:06 AM   #7
CAL 58 GMC
CAL 58 GMC's Avatar
That's amazing how well that works on removing all of that rust!
CAL 58 GMC is offline   Reply With Quote
Old 09-07-2006, 02:42 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
I have some inner fenders that I had preped by a resto body shop and have just found that under the good looking primer is a layer of rust. So I'll be trying this out real soon.
Old 09-11-2006, 08:33 AM   #9
bretcopsey
I have gotten a little more acomplished. I shaved the front bumper...
My 51 project
Old 09-11-2006, 08:35 AM   #10
bretcopsey
I also started pounding out the front dr side fender. I wanted to have a clean piece to metal work so now it is soaking in the acid bath, and I will update the progress if you'd like. Right now it is 30 gallon tub with 1.5 gallons of acid. I sanded the exterior and left the inside surface as it was.
My 51 project
Old 09-11-2006, 08:39 AM   #11
bretcopsey
Here's a 'before' for comparison.
My 51 project
Old 09-11-2006, 08:41 AM   #12
bretcopsey
Lastly, I started work on the dr side cowl. This was a parts truck, and someone had previously cut out this panel for a patch. I drilled out the spot welds and am about ready to start fitting the replacement panel. I just need to repair the hinge mount areas first.
My 51 project
Old 09-11-2006, 03:15 PM   #13
texascowboy593
texascowboy593's Avatar
Looks like its coming along well... Keep us posted!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 09-18-2006, 09:35 AM   #14
bretcopsey
Not to run this into the ground, but here is one more of the fender above after soaking in the 'bath.' Unfortunately, we had some rain, so everything that wasn't submerged got pretty nasty looking
You can see that while this works on the heavier rust, it is better to knock off what you can by sanding to get better results. The solution weakens as the rust is desolved
Also, this tile cleaner stuff does work well, but seems to have some detergent in it as well, because it foams up something aweful. I might be going back to the previous product I was using if I can find it! I'll fill you in when there is more to update!
My 51 project
Old 09-18-2006, 09:43 AM   #15
layedoutnoma
layedoutnoma's Avatar
looks like all i need is a bin big enough for a bed and cab and ii'm all set... maybe the swimming pool would work..
Meticulous Fabrications
Milford Michigan
layedoutnoma is offline   Reply With Quote
Old 09-22-2006, 12:37 AM   #16
gr8one
does the acid remove the paint?
gr8one is offline   Reply With Quote
Old 09-22-2006, 08:44 AM   #17
bretcopsey
In general, if the paint is in good condition, it will not be removed. I cannot say that there wiould not be long term effects though. I plan on removing all paint remaining by sanding off.
If you look at the pictures above, the paint in the recess for the headlight bucket is still intact. The paint that was already failing did come off, as well as the oxidation on some of the paint in a little better condition-see the small blue dot on the next to last picture above.
My 51 project
Old 10-14-2006, 12:53 PM   #18
Daniel U
Daniel U's Avatar
yup, very ambitious! "Build'em don't crush'em."
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 10-14-2006, 09:03 PM   #19
55ChevyPU
55ChevyPU's Avatar
I get scared everytime I see your truck GL
55ChevyPU is offline   Reply With Quote
Old 10-16-2006, 08:50 AM   #20
bretcopsey
Me too!! Kidding, of course. I've been plugging away lately and been too busy to post some updates. I also lost a bunch of pictures from my camera.
I almost have the frame clip done. The only sheetmetal to 'de-rust' is the hood and cab, both of which are a little too big to fit in my 'dip tank' so I've got to come up with a creative solution for that...
Hopefully more to come in the next couple days!
My 51 project
Old 10-20-2006, 08:46 AM   #21
bretcopsey
As promised (or threatened, depending on if this truck scares you LOL!!)
Fenders after dip-flash rust is a problem. After wiping down with undiluted acid, problem resolved.
My 51 project
Old 10-20-2006, 08:47 AM   #22
bretcopsey
Inner fenders. Majority done, but need some touchup. Also starting on hood.
My 51 project
Old 10-20-2006, 08:50 AM   #23
bretcopsey
Camaro frame clip, in the middle of the grafting process.
My 51 project
Old 10-20-2006, 08:51 AM   #24
bretcopsey
And some dash pieces I just won on eBay.
My 51 project
Old 10-20-2006, 08:52 AM   #25
bretcopsey
That's it for now. I hope to get the bed off and finish boxing in the frame this weekend. If time allows, maybe even finish the hood. I'm working as fast as I can now before it gets too cold to be in the driveway!!
My 51 project
