small or big hump and tranny question
do i have a small or big hump 1965 c10 230 strait six born with a powerglide now has a 350TH. and do you think a 4L85E tranny will fit?
also does anybody know what the large spring is for? i know the small one is for my jack. thank you ![]() ![]()
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 05-27-2012 at 09:06 PM. Reason: spelling |
Re: small or big hump and tranny question
I believe the large spring holds the lug wrench and jack handle down.
Senior Enthusiast
Can't help with the floor question, but the long spring is for retaining the jack handle and lug wrench. Posts #4 & 13 include diagrams showing the layout:
http://67-72chevytrucks.com/vboard/s...t=factory+jack Just read you question again - you definitely have the small hump. I just don't know if the 4L85E trans will fit. Here is a picture of a high hump. The pan is almost square in the center, rises up in front of the seat, and is always removable: ![]() The low hump drops in front of the seat, may be removable or may be a permanent part of the floor. From all the threads I’ve read on this topic, they are not directly interchangeable, however a high hump can be added to a low hump truck if the portion from the high hump donor truck in front of the removable pan is also cut out and welded into the low hump cab.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 05-27-2012 at 09:26 PM. |
That looks like a small hump to me, the big humps are BIG, usually 4x4's. The spring I believe is the hold down for the factory jack, not 100% certain of that, but that is my guess.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
If you dig around on here you will see some big humps
CRGRS66 beat me to it, lol. Yeah the big hump you would know if you have it. The hump you have under your seat there...its the same on all trucks. Its the part of the floor thats in front of that. A 4 speed truck floor, is way taller between the firewall and the seat. Powerglide and 3 speed trucks have your floor. The 66 year had the turbo 400 availible and it also has the same floor as yours. I dont have a pic handy. But i have a big hump with a 4 speed SM420 trans. 4 speed floors are also removable. There is a legend out there about the early trucks that had a removable small hump, but i havent seen pics of it. Im not sure on the fit of the newer trans, but the 700r4 supposedly just bumps the floor pan seam that runs side to side, like where your feet go, and some guys just peen it over near where it touches.
You have a small hump. The large hump will line up flush to that rolled seam you have near the edge and extend about 4 inches past the end of your existing floor cover. If you find someone parting out a truck with a large hump, make sure you get the 2nd piece that is spot welded to the tranny tunnel. This is needed or you will have a gap between the end of the hump and the firewall.
Good call ABX131, i forgot to mention that.
Heres a high hump. This is from a fellow member(rossboss). I hope he doesnt mind.
Will a 700R4 fit under the low hump?
![]() Join Date: Sep 2009
had a 350 now 2004r low hump and both fit fine. no altering at all
I heard that the low hump will just touch on the 700R4 on the floorpan seam where it connects to the firewall(sidetoside seam) .
#13 | |
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
If you get time, post a picture. Either of the cab floor or the hump itself. Ive never seen one.
#15 |
![]() Join Date: Feb 2011
I have a small hump 66 swb with a 4L60E it clears. i think the 4L80E is larger and will need the large hump.kenny
#16 | |
Senior Enthusiast
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#17 |
![]() Join Date: Nov 2011
Mine looks like that. 1962 SWB BBW side step built in the Los Angeles plant.
Posted via Mobile Device |
#18 | |
Anyone else have more info on the bolt in low hump?
#19 |
Wow, thats cool! Never seen that before. Any reason they might do that in the early trucks and not 456 years?
#20 |
Mine has the picture sigshooter posted. It is '63 Short Step built in St Louis with a 230/3 on the tree.
292 + TKO500 |
#21 |
![]() Join Date: Mar 2011
I'm putting a 4L80 in my 1960. The 60 cab I have has the removable high hump but I have a weld in low hump that I'm going to try really hard to use. It will be a while until I get there, I hope you have good results!
http://67-72chevytrucks.com/vboard/s...d.php?t=456437 |
#22 |
These shots are of my 1962 removable small hump.
#23 |
Wow Trap, nice low rust original floor/cab! No patch panels, even the rockers are original?! Rarely see that anymore!
292 + TKO500 |
#24 |
Dam,that floor is clean & rust free!!!
