Rear mount Gas tank question...
I just finished mounting an LMC gas tank in my 64. However, I had a question on the vents on the tank. Besides the filler and sending unit, do I need to run any vents or returns? I would apprecaite any input or pics anyone can supply.
THanks! |
Re: Rear mount Gas tank question...
I'm thinking about the same tank, how low does it hang down? How was the install?
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
If your not running a vented cap you`ll need to put a pigtail vent in the tank.. there are two trains of thought on a return line, stock mechanical pump you don`t need a return line,( although GM used a return lines on the `69 camaros with stock pumps ) electric pump you should run a return line, 3/8 or larger to the carb and 5/16 back to the tank and return needs to run almost to the bottom of the tank to eliminate vapors, this prevents the electric pump from deadheading the fuel pressure and creating excessive heat and causing the pump to shut down, (thermal overload protection ).
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#5 | |
make sure you post some pictures (if it's not too much trouble). I need to decide on a tank soon...
![]() Join Date: Nov 2007
My tank came with a vent fitting on the top of the tank. It also came with a check valve so that gas won't run out of the vent in case you put the shiny side down.
Here is a pic. I picked up the screen filter at Advance. I mounted it up between the inner fender and the bed side. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
