Old 06-04-2012, 01:28 PM   #1
84_chevy
Sensor
I have a sensor right above the oil filter without a wire attached to it, anyone knows what it's for? It's an 80's block.
84_chevy is offline   Reply With Quote
Old 06-04-2012, 04:21 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Sensor
In the oil port? lots of people use that one for aftermarket oil gauges (low-presure warning light, electric fuel cut-off switch etc) when the stock port at the back of the intake is occupied by the stock sender.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-04-2012, 06:37 PM   #3
84_chevy
Re: Sensor
I'm not to sure what you mean by the "oil port" it look to me to be directly above the oil filter in the block. Is that the oil port? Would it register low oil if the truck had a low oil light warning light?
Old 06-04-2012, 07:47 PM   #4
clinebarger
Re: Sensor
If it has two prongs on it.....Its a electric choke switch, Its purpose was to power the choke only with the engine running.
clinebarger is offline   Reply With Quote
Old 06-04-2012, 08:06 PM   #5
84_chevy
Re: Sensor
Single prong
