Old 06-04-2012, 12:01 AM   #1
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Crossmember removal with the engine in place
I'm intending to swap a clean, painted, disk brake front end into the '68. Obviously, I have to unhook the bottom end of the front motor mounts from the x-member to do so. I'd leave the top of the mount attached to the frame, then put a come-along between the frame rails. If I don't support the motor from above, will the frame horns roll under and/or splay out?
I know the better option is to do the suspension work with the motor out, but that's in the cards anytime soon. What have you guys done here? Thanks.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 06-04-2012, 08:06 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Crossmember removal with the engine in place
I haven't tried it with the engine in so I may be missing something but I always figured I would block the engine up under the pan after I had the jack stands under the frame. Maybe that wouldn't leave enough room to get the cross member assembly out. I haven't really looked at one that close with the engine in.... I bet it isn't going to be a lot of fun with the engine in.
LockDoc
Leon
