Whats the softest Riding 4 inch lift ?
I have a 4 inch all spring lift in my 1992 Dodge from Skyjacker with a set of Bilsteins Its okay but the Chevy is going to be much lighter and is a short bed so choppy I emailed and Called Deaver but just wondering what other options i may have. Thank you |
Re: Whats the softest Riding 4 inch lift ?
That is a pretty hard question to answer. in order to know, you would have had to install kits from several manufacturers on the same truck with the same tires and wheels.
Shackle-flip rear and longer springs
52s up front and 64s out back...
Charlie Daniels w/ a Tq Wrench
These will be your softest, flexiest options. But for off the shelf, direct bolt on springs, it's hard to beat the ride of Tuff Country springs.
Skyjacker, Superlift, and Rough Country are all pretty well known to ride pretty stiff.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
shackle flip and 52/62 ok were would I start looking for this application more so what springs and were would I buy them from ?
Thank you |
52s are rear pickup/Blazer/Jimmy springs up to '88 truck & '91 Blazer/Jimmy. 62s are rear springs off an '88 or newer truck/Suburban/Tahoe/Yukon. www.offroaddesign.com for the shackle flip
#8 | |
so far as i know, they are 64" not 62" you can also find 60" rear springs from a suburban.
#10 | ||
![]() Join Date: Oct 2006
You can also have custom springs made to YOUR specs by Alcan or Deaver.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
I also am thinking about 52s up front is anyone running 38s and 52s up front if so what lift 52 are you running and did you fan your own brackets or purchase the kit from diy4x? I have stock 52s but I don't think it will clear 38s or even a wider set of 35s
Depending on the condition of the springs, they normally get around 4-4 1/2" of lift. I ran 38.5" boggers with 4", but cut the crap out of the fenders...
Also don't need a kit to run 52s, move the forward spring mounts forward, it all bolts in.... |
But doesn't that locate the tire forward or back in the fender well ?
#15 | |
Yes. 67-72 springs are 44" 73-87 springs are 47", this mod puts 52" up front. All springs have centered locating pins. Going forward ~3-4" would keep the axle located in the same place, but generally, if you intend to use your truck offroad you will want to go even farther forward for more tire clearance at the firewall/rear of fender. With the longer flexier springs, as your suspension compresses, your axle will move rearward towards the firewall farther than the stock springs. Also it gives your more front driveshaft length for a better angle, less wear on u-joints and less binding.
