Old 06-06-2012, 07:17 PM   #1
3r!c84
Badass
3r!c84's Avatar
lowering with headers?
hey guys what headers are you running when lowering your truck. ive got 5/5 drop (3inch sprindle 1 cut coil and flip kit) i find my self wanting to go lower now. a static drop. like c-notch and drop shackles and lowering springs.
ive got long tube headers that are made for these years of trucks and they hang pretty low already..
here are some pics.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 06-06-2012, 08:03 PM   #2
badpontiacs
badpontiacs's Avatar
Re: lowering with headers?
i have a bagged dually with headers, im close but dont hit. I can raise up though so not 100% sure i would do it, try some shorty or mid length. That would probably be more suitable for driving at a dropped stance. Looks great as is, I think....my .02
badpontiacs is offline   Reply With Quote
Old 06-06-2012, 09:35 PM   #3
3r!c84
Badass
3r!c84's Avatar
i hear chevelle long tubes fit and dont hang under the frame rail. i want to make sure first . just want more low. with out bags...
-00 Saturn 5spd
1/4:13:90
Old 06-06-2012, 09:36 PM   #4
3r!c84
Badass
3r!c84's Avatar
btw: this is for a sbc
-00 Saturn 5spd
1/4:13:90
Old 06-07-2012, 02:09 AM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
I have a 6-8 drop and I just weld a 1/4 inch plate on the headers and drag all the roadkill and speedbumps withe me I hear that some flotech camaro headers fit well and don't hang low as well as slugs and Doug thorley
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-12-2012, 11:31 PM   #6
3r!c84
Badass
3r!c84's Avatar
anyone?
-00 Saturn 5spd
1/4:13:90
Old 06-13-2012, 12:28 AM   #7
cochino12
It followed me home?
cochino12's Avatar
Ive always run 70's camaro headers, really close to the passenger frame rail but no issues yet.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 06-13-2012, 12:43 AM   #8
3r!c84
Badass
3r!c84's Avatar
long tubes? got any pictures?
-00 Saturn 5spd
1/4:13:90
Old 06-13-2012, 01:56 AM   #9
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
long tubes wont work. I've got the skip white chevelle headers. can't beat em.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-13-2012, 04:26 AM   #10
gGMC DOG
I got the headers that Nate from pb susgested from summit and they fit really nice
with a 5/7 static drop
http://www.summitracing.com/parts/HOK-2466HKR/
gGMC DOG is offline   Reply With Quote
Old 06-14-2012, 02:33 AM   #11
dbmx66
depends on how low you go, i got away (just barely) with a 7 inch front drop.
after i channeled my front crossmember 2.5 inches. bye bye full length. that put me at 9-9.5 inches of front static drop and thats not including the smaller tire diameter as well (25.5x5). im about 12-13 inches in the rear do to the 33X19.5s.
i was gonna throw shortys on, but i dont want loose all the airflow (which means less power). so my brother and i started these fender exit headers.
i dont have any pics of the individual pipes. but the stahl flanges with 2 inch primaries and 3.5 inch collectors. there just tacked right now as we speak, waiting for my bro to tig weld them, then there getting sent to be ceramic coated.
BTW it doesnt look like it in the picture, but my rocker panels are around 3-4 inches off ground.
dbmx66 is offline   Reply With Quote
Old 06-14-2012, 02:45 AM   #12
3r!c84
Badass
3r!c84's Avatar
didnt you have a build thread? i lost it i think. i remember your race truck. i like the side exits but a little to loud and not my plan of how i want it to look lol. i want my exhaust ran out behind the rear tire... but dont think that till happen when i do a AOL system.. /:
-00 Saturn 5spd
1/4:13:90
Old 06-14-2012, 10:46 AM   #13
KQQL IT
At the body shop.
KQQL IT's Avatar
Dougs D310c
Old 06-14-2012, 11:13 AM   #14
dbmx66
Originally Posted by KQQL IT View Post
Dougs D310c
where you get those upper shock mounts?
Old 06-14-2012, 11:41 AM   #15
KQQL IT
At the body shop.
KQQL IT's Avatar
Lol 81 up 4x4 square with factory dual shocks. Its the second shoc mount
Old 06-14-2012, 11:45 AM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
Like so.
Old 06-14-2012, 08:57 PM   #17
dbmx66
Did you bolt those on? Or weld? Did you utilize the hole in the frame for the original mount?
Old 06-14-2012, 09:17 PM   #18
KQQL IT
At the body shop.
KQQL IT's Avatar
Bolted. And just above and behind the stock hole.
Old 06-14-2012, 09:20 PM   #19
slugish
Slugish
been running cheap Hedman long tubes with a 5.5 front drop for 8 yrs. now . Thought about replacing them when engine was out this year, but just ended up painting them > still in good shape ,other than a little flattened spot where its hit pavement before . Sort of like one of the other posts where they welded a plate on the lowest point . Good luck
slugish is offline   Reply With Quote
Old 06-14-2012, 10:06 PM   #20
3r!c84
Badass
3r!c84's Avatar
i plan on bagging the truck and want to lay on the cross member . not lay frame. so want to to be side of the frame rails to be safe. unlike what i have now they hang pretty low already with 5/5 drop
-00 Saturn 5spd
1/4:13:90
Old 06-14-2012, 10:17 PM   #21
3r!c84
Badass
3r!c84's Avatar
here are some pics of how low they hang
-00 Saturn 5spd
1/4:13:90
Old 06-15-2012, 02:14 AM   #22
INSIDIOUS '86
Those are low!! If you want full.length and full power you have a few options either cut and weld. Try some camaro headers or go with dougs
