Old 06-16-2012, 08:53 PM   #1
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
Alternative fix for vaccum and air pressure plumbing.
I made this setup for Shawno72 and will try and explain how I did it and what parts were used. I hope some of you can get some use out of this method. Shawn was missing the nut that mounted the gauge to the tin and most of you know it is a thin type nut like an oil pressure gauge but it is fine thread. I determined that is 1/8 27 NPT thread which is pipe thread. This is how I fixed this problem. Go to any of you local hardware stores and purchase a 1/4" MIP x 1/8" FIP pipe hex bushing. I put the bushing in a vise and used a 3/8 drill bit and from the opposite side of the nut (nut side in the vise) drilled about 3/4 of the way down into the bushing because the bushing is tapered. Step 2 flip the bushing over in the vise and use a 1/8 x 27 NPT pipe tap and tap the inside of the bushing all the way through. This bushing then will thread onto the vac/air pressure gauge all the way down to mount the gauge to the tin. Then I used a 1/4" barb x 1/4" FIP nipple and most refer to this as a (king nipple) this will allow you to slide your rubber hose onto the nipple and it will self fasten or use a hose clamp for more insurance. This method is modern and will allow you to go to any local hardware store and buy any fitting you desire and you can hard pipe it with tubing or use rubber hose. All of the drilling and taping was done because Shawn did not have a nut to fasten his gauge to the tin.
PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 06-16-2012, 09:33 PM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: Alternative fix for vaccum and air pressure plumbing.
That looks very sanitary!! Thanks for all your effort to make this happen PT.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 06-16-2012, 09:48 PM   #3
Lee H
Lee H's Avatar
Nice, thank you for sharing.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-16-2012, 10:43 PM   #4
PT'S 70 CST
"GO DAWGS"
No problem Shawn just glad I could help.
PT
70 CST SWB
70 NOVA
2000 Silverado swb
29006
