Old 08-07-2012, 06:55 PM   #1
Chevy072
Moser Ford 9" axle housing w/31 spline axles
This kit was installed around a year ago and just sat not being used. Retail is over $1000. This bolts right into your 67-72 truck with trailing arms. All you need to do is pick up a 9" center chunk with your choice of gears, etc. NEW PRICE $350 picked up.
I also have the leafspring mounts for this that need to be welded in place. I will check to make sure they are the right ones because they were just sitting in the cab.
I want to clarify that this is not a Ford rearend,but is produced by moser engineering. They have modeled this housing after the Ford 9". The wheel studs are 4 on 4.75
Chevy072 is offline   Reply With Quote
Old 08-07-2012, 07:09 PM   #2
lucifer
lucifer's Avatar
Re: Moser Ford 9" axle housing w/31 spline axles
Originally Posted by Chevy072 View Post
This kit was installed around a year ago and just sat not being used. Retail is over $1000. This bolts right into your 67-72 truck with trailing arms. All you need to do is pick up a 9" center chunk with your choice of gears, etc. $500 o.b.o picked up.
Does it maintain the stock width??
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 08-07-2012, 08:20 PM   #3
Chevy072
housing itself is approx. 60-1/2" and outer axle to outer axle is approx 66-1/2
Old 08-08-2012, 03:35 PM   #4
Chevy072
anyone interested? I do have the drum brakes for this,but they have been sitting for a while and will need to be cleaned up.
Old 08-09-2012, 02:04 PM   #5
Chevy072
offer?
Old 08-10-2012, 07:22 PM   #6
Chevy072
Offer?
Old 08-11-2012, 02:00 PM   #7
Chevy072
New price $400
Old 08-11-2012, 10:36 PM   #8
PRORIDES
PRORIDES's Avatar
Would you ship it to PA? Thanks
64 C10 Dropmember.... Sold
79 C10 Dropmember
97 Dually Airride (Shop Truck)
PRORIDES is offline   Reply With Quote
Old 08-11-2012, 10:54 PM   #9
Chevy072
Sure would. I will let you know tomorrow on what it would cost to get it there.
Old 08-12-2012, 10:08 AM   #10
Chevy072
Not sure of your zip code,but Fedex to 15219 would be around $130 for shipping. That is with me just wrapping it. If it was crated it would be more. I can get a crated quote on monday through engines direct
Old 08-12-2012, 10:21 AM   #11
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
bump for a great deal, wish I could use it
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 08-13-2012, 09:19 AM   #12
Chevy072
good morning
Old 08-14-2012, 08:20 AM   #13
Chevy072
no interest?
Old 08-15-2012, 08:42 AM   #14
Chevy072
Anyone? This is around 1/3 of the retail price.
Old 08-16-2012, 08:50 AM   #15
Chevy072
ttt
Old 08-17-2012, 09:09 AM   #16
Chevy072
anyone?
Old 08-18-2012, 09:59 AM   #17
Chevy072
bump
Old 08-19-2012, 10:53 AM   #18
Chevy072
ttt
Old 08-20-2012, 12:05 PM   #19
Chevy072
bump
Old 08-21-2012, 10:15 AM   #20
Chevy072
ttt
Old 08-22-2012, 09:14 AM   #21
Chevy072
Anyone interested?
Old 08-23-2012, 09:07 AM   #22
Chevy072
ttt
Old 08-24-2012, 11:12 AM   #23
duallyjams
duallyjams's Avatar
This kit was installed around a year ago and just sat not being used. Retail is over $1000. This bolts right into your 67-72 truck with trailing arms. All you need to do is pick up a 9" center chunk with your choice of gears, etc. NEW PRICE $400 picked up.
Do you still have the build sheet for this to show what bearing , wheel stud that you chose also this package on moser site comes with brakes and the moser site shows 63-69 and the 70-72 as different width.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 09-01-2012, 09:31 AM   #24
Chevy072
No i don't have the build sheet. I did not purchase this directly. The wheel studs are 7/16 by 1-1/4". The do not come standard with brakes,but can be ordered that way. I do have drum brakes for it that have been sitting out and will need some freshening up. The wheel studs are 4 on 4.75 which i thought was strange that this was ordered like that,but then i checked the front disk setup with tubular control arms and it was also 4 on 4.75,so im guessing that this was ordered that way for a reason. The bearings would be moser or timkin ball bearing type according to moser tech support. They do not use cheap bearings. It also has the c-clip eliminator type on it. The housing itself is 60.5" long and outside to outside on the axles without counting the studs is 65.5"
Old 09-07-2012, 08:57 AM   #25
Chevy072
ttt
